Selamat Pagi
master - master ada yang mau saya tanyakan udah mentok banget cari solusi belum ketemu - ketemu,
Jadi saya mau bikin Webrct bisa call ke nomor SIP dan PSTN lewat SIP trunk, tapi gagal terus
Untuk pengetesan sebegai berikut :
webrct => SIP OK
webrct => PSTN NOK
webrct => webrct OK
SIP => webrct OK
SIP => PSTN OK
SIP => SIP OK
Terima kasih banyak sebelumnya ya
FYI, untul sipuri misal 500 @domain_name sengaja di kasih spasi setelah nomor soalnya di anggap link dan gk bisa di post disini
webrct => PSTN gagal dan error muncul seperti ini :
Aug 16 11:25:16 esbdev01 /usr/sbin/kamailio[28300]: INFO: : START WEBSOCKET : INVITE from sip:500@domain.name (IP:127.0.0.1:43402) websocket id 12
Aug 16 11:25:16 esbdev01 /usr/sbin/kamailio[28300]: INFO: : MANAGE_BRANCH: New branch [0] to sip:+6282311XXXXXX@IP_SIP_TRUNK:5060
Aug 16 11:25:16 esbdev01 /usr/sbin/kamailio[28300]: INFO: : NATMANAGE branch_id:0 ruri: sip:+6282311XXXXXX@IP_SIP_TRUNK:5060, method:INVITE, status:, extra_id: z9hG4bK46635730, rtpengine_manage: replace-origin replace-session-connection via-branch=extra rtcp-mux-demux DTLS=off SDES-off ICE=remove RTP/AVP
Aug 16 11:25:16 esbdev01 rtpengine[16670]: INFO: [eq07esfe0a3mcjvpait6]: [control] Received command ‘offer’ from 127.0.0.1:38616
Aug 16 11:25:16 esbdev01 rtpengine[16670]: NOTICE: [eq07esfe0a3mcjvpait6]: [core] Creating new call
Aug 16 11:25:16 esbdev01 rtpengine[16670]: WARNING: [eq07esfe0a3mcjvpait6]: [core] Ignoring updated remote endpoint as the local socket is IPv4
Aug 16 11:25:16 esbdev01 rtpengine[16670]: INFO: [eq07esfe0a3mcjvpait6]: [control] Replying to ‘offer’ from 127.0.0.1:38616 (elapsed time 0.005891 sec)
Aug 16 11:25:16 esbdev01 /usr/sbin/kamailio[28280]: INFO: : BRANCH FAILED: z9hG4bK4663573 + 0
Aug 16 11:25:16 esbdev01 rtpengine[16670]: INFO: [eq07esfe0a3mcjvpait6]: [control] Received command ‘delete’ from 127.0.0.1:44664
Aug 16 11:25:16 esbdev01 rtpengine[16670]: INFO: [eq07esfe0a3mcjvpait6]: [core] Scheduling deletion of call branch ‘’ (via-branch ‘z9hG4bK46635730’) in 30 seconds
Aug 16 11:25:16 esbdev01 rtpengine[16670]: INFO: [eq07esfe0a3mcjvpait6]: [control] Replying to ‘delete’ from 127.0.0.1:44664 (elapsed time 0.000210 sec)
Aug 16 11:25:16 esbdev01 /usr/sbin/kamailio[28280]: INFO: : Failure:
berikut debug webrct-nya :
LoggerFactory.js:100 Mon Aug 16 2021 10:42:54 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | SessionDescriptionHandlerOptions: {“peerConnectionOptions”:{“rtcConfiguration”:{“iceServers”:[{“urls”:“turn:domain_name:443?transport=tcp”,“username”:“websip”,“credential”:“websip”},{“urls”:“turns:domain_name:80?transport=tcp”,“username”:“websip”,“credential”:“websip”}]},“iceCheckingTimeout”:5000}}
LoggerFactory.js:100 Mon Aug 16 2021 10:42:54 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | initPeerConnection
LoggerFactory.js:100 Mon Aug 16 2021 10:42:54 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | New peer connection created
LoggerFactory.js:100 Mon Aug 16 2021 10:42:54 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | acquiring local media
LoggerFactory.js:100 Mon Aug 16 2021 10:42:55 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | acquired local media streams
LoggerFactory.js:100 Mon Aug 16 2021 10:42:55 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | createOffer
LoggerFactory.js:100 Mon Aug 16 2021 10:42:55 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | resetIceGatheringComplete
LoggerFactory.js:100 Mon Aug 16 2021 10:42:55 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | Setting local sdp.
LoggerFactory.js:100 Mon Aug 16 2021 10:42:55 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | sdp is v=0
o=- 5499752371154858348 2 IN IP4 127.0.0.1
s=-
t=0 0
a=group:BUNDLE 0 1
a=extmap-allow-mixed
a=msid-semantic: WMS 2yMfiToO0B0g0rBtLDd7vEaYmQ9PrZ0QUC9w
m=audio 9 UDP/TLS/RTP/SAVPF 111 103 104 9 0 8 106 105 13 110 112 113 126
c=IN IP4 0.0.0.0
a=rtcp:9 IN IP4 0.0.0.0
a=ice-ufrag:c/YU
a=ice-pwd:7VB8/SEvBOYMyPpKgYKzOpPK
a=ice-options:trickle
a=fingerprint:sha-256 92:73:F2:E2:70:7C:43:BD:59:3A:6C:F3:7D:B9:9F:75:19:81:4C:40:0E:DA:63:D9:FF:90:60:41:49:E6:B0:9C
a=setup:actpass
a=mid:0
a=extmap:1 urn:ietf:params:rtp-hdrext:ssrc-audio-level
a=extmap:2 urn:ietf:params:rtp-hdrext:sdes:mid
a=extmap:3 urn:ietf:params:rtp-hdrext:sdes:rtp-stream-id
a=extmap:4 urn:ietf:params:rtp-hdrext:sdes:repaired-rtp-stream-id
a=sendrecv
a=msid:2yMfiToO0B0g0rBtLDd7vEaYmQ9PrZ0QUC9w f8941c64-0252-4ab7-b1c5-3731f47c9fd7
a=rtcp-mux
a=rtpmap:111 opus/48000/2
a=rtcp-fb:111 transport-cc
a=fmtp:111 minptime=10;useinbandfec=1
a=rtpmap:103 ISAC/16000
a=rtpmap:104 ISAC/32000
a=rtpmap:9 G722/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:106 CN/32000
a=rtpmap:105 CN/16000
a=rtpmap:13 CN/8000
a=rtpmap:110 telephone-event/48000
a=rtpmap:112 telephone-event/32000
a=rtpmap:113 telephone-event/16000
a=rtpmap:126 telephone-event/8000
a=ssrc:3068753223 cname:vdFflh5e6U+kdnYw
a=ssrc:3068753223 msid:2yMfiToO0B0g0rBtLDd7vEaYmQ9PrZ0QUC9w f8941c64-0252-4ab7-b1c5-3731f47c9fd7
a=ssrc:3068753223 mslabel:2yMfiToO0B0g0rBtLDd7vEaYmQ9PrZ0QUC9w
a=ssrc:3068753223 label:f8941c64-0252-4ab7-b1c5-3731f47c9fd7
m=video 9 UDP/TLS/RTP/SAVPF 96 97 98 99 100 101 102 121 127 120 125 107 108 109 35 36 124 119 123 118 114 115 116
c=IN IP4 0.0.0.0
a=ice-ufrag:c/YU
a=setup:actpass
a=mid:1
a=extmap:4 urn:ietf:params:rtp-hdrext:sdes:mid
a=extmap:5 urn:ietf:params:rtp-hdrext:sdes:rtp-stream-id
a=extmap:6 urn:ietf:params:rtp-hdrext:sdes:repaired-rtp-stream-id
a=sendrecv
a=msid:2yMfiToO0B0g0rBtLDd7vEaYmQ9PrZ0QUC9w 1e978692-178f-46cb-8c18-8f130343f637
a=rtcp-mux
a=rtcp-rsize
a=rtpmap:96 VP8/90000
a=rtcp-fb:96 goog-remb
a=rtcp-fb:96 transport-cc
a=rtcp-fb:96 ccm fir
a=rtcp-fb:96 nack
a=rtcp-fb:96 nack pli
a=rtpmap:97 rtx/90000
a=fmtp:97 apt=96
a=rtpmap:98 VP9/90000
a=rtcp-fb:98 goog-remb
a=rtcp-fb:98 transport-cc
a=rtcp-fb:98 ccm fir
a=rtcp-fb:98 nack
a=rtcp-fb:98 nack pli
a=fmtp:98 profile-id=0
a=rtpmap:99 rtx/90000
a=fmtp:99 apt=98
a=rtpmap:100 VP9/90000
a=rtcp-fb:100 goog-remb
a=rtcp-fb:100 transport-cc
a=rtcp-fb:100 ccm fir
a=rtcp-fb:100 nack
a=rtcp-fb:100 nack pli
a=fmtp:100 profile-id=2
a=rtpmap:101 rtx/90000
a=fmtp:101 apt=100
a=rtpmap:102 H264/90000
a=rtcp-fb:102 goog-remb
a=rtcp-fb:102 transport-cc
a=rtcp-fb:102 ccm fir
a=rtcp-fb:102 nack
a=rtcp-fb:102 nack pli
a=fmtp:102 level-asymmetry-allowed=1;packetization-mode=1;profile-level-id=42001f
a=rtpmap:121 rtx/90000
a=fmtp:121 apt=102
a=rtpmap:127 H264/90000
a=rtcp-fb:127 goog-remb
a=rtcp-fb:127 transport-cc
a=rtcp-fb:127 ccm fir
a=rtcp-fb:127 nack
a=rtcp-fb:127 nack pli
a=fmtp:127 level-asymmetry-allowed=1;packetization-mode=0;profile-level-id=42001f
a=rtpmap:120 rtx/90000
a=fmtp:120 apt=127
a=rtpmap:125 H264/90000
a=rtcp-fb:125 goog-remb
a=rtcp-fb:125 transport-cc
a=rtcp-fb:125 ccm fir
a=rtcp-fb:125 nack
a=rtcp-fb:125 nack pli
a=fmtp:125 level-asymmetry-allowed=1;packetization-mode=1;profile-level-id=42e01f
a=rtpmap:107 rtx/90000
a=fmtp:107 apt=125
a=rtpmap:108 H264/90000
a=rtcp-fb:108 goog-remb
a=rtcp-fb:108 transport-cc
a=rtcp-fb:108 ccm fir
a=rtcp-fb:108 nack
a=rtcp-fb:108 nack pli
a=fmtp:108 level-asymmetry-allowed=1;packetization-mode=0;profile-level-id=42e01f
a=rtpmap:109 rtx/90000
a=fmtp:109 apt=108
a=rtpmap:35 AV1X/90000
a=rtcp-fb:35 goog-remb
a=rtcp-fb:35 transport-cc
a=rtcp-fb:35 ccm fir
a=rtcp-fb:35 nack
a=rtcp-fb:35 nack pli
a=rtpmap:36 rtx/90000
a=fmtp:36 apt=35
a=rtpmap:124 H264/90000
a=rtcp-fb:124 goog-remb
a=rtcp-fb:124 transport-cc
a=rtcp-fb:124 ccm fir
a=rtcp-fb:124 nack
a=rtcp-fb:124 nack pli
a=fmtp:124 level-asymmetry-allowed=1;packetization-mode=1;profile-level-id=4d0032
a=rtpmap:119 rtx/90000
a=fmtp:119 apt=124
a=rtpmap:123 H264/90000
a=rtcp-fb:123 goog-remb
a=rtcp-fb:123 transport-cc
a=rtcp-fb:123 ccm fir
a=rtcp-fb:123 nack
a=rtcp-fb:123 nack pli
a=fmtp:123 level-asymmetry-allowed=1;packetization-mode=1;profile-level-id=640032
a=rtpmap:118 rtx/90000
a=fmtp:118 apt=123
a=rtpmap:114 red/90000
a=rtpmap:115 rtx/90000
a=fmtp:115 apt=114
a=rtpmap:116 ulpfec/90000
a=ssrc-group:FID 1593038176 4012956172
a=ssrc:1593038176 cname:vdFflh5e6U+kdnYw
a=ssrc:1593038176 msid:2yMfiToO0B0g0rBtLDd7vEaYmQ9PrZ0QUC9w 1e978692-178f-46cb-8c18-8f130343f637
a=ssrc:1593038176 mslabel:2yMfiToO0B0g0rBtLDd7vEaYmQ9PrZ0QUC9w
a=ssrc:1593038176 label:1e978692-178f-46cb-8c18-8f130343f637
a=ssrc:4012956172 cname:vdFflh5e6U+kdnYw
a=ssrc:4012956172 msid:2yMfiToO0B0g0rBtLDd7vEaYmQ9PrZ0QUC9w 1e978692-178f-46cb-8c18-8f130343f637
a=ssrc:4012956172 mslabel:2yMfiToO0B0g0rBtLDd7vEaYmQ9PrZ0QUC9w
a=ssrc:4012956172 label:1e978692-178f-46cb-8c18-8f130343f637
LoggerFactory.js:100 Mon Aug 16 2021 10:42:55 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | waitForIceGatheringComplete
LoggerFactory.js:100 Mon Aug 16 2021 10:42:55 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | ICE is not complete. Returning promise
LoggerFactory.js:100 Mon Aug 16 2021 10:42:55 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | RTCIceGatheringState changed: gathering
LoggerFactory.js:100 Mon Aug 16 2021 10:42:55 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | ICE candidate received: candidate:3250795810 1 udp 2122260223 10.XX.XX.XX 63469 typ host generation 0 ufrag c/YU network-id 2 network-cost 50
LoggerFactory.js:100 Mon Aug 16 2021 10:42:55 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | ICE candidate received: candidate:211156821 1 udp 2122194687 192.XXX.X.X 50637 typ host generation 0 ufrag c/YU network-id 1 network-cost 10
LoggerFactory.js:100 Mon Aug 16 2021 10:42:55 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | ICE candidate received: candidate:3250795810 1 udp 2122260223 10.XX.XX.XX 55429 typ host generation 0 ufrag c/YU network-id 2 network-cost 50
LoggerFactory.js:100 Mon Aug 16 2021 10:42:55 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | ICE candidate received: candidate:211156821 1 udp 2122194687 192.XXX.X.X 50147 typ host generation 0 ufrag c/YU network-id 1 network-cost 10
LoggerFactory.js:100 Mon Aug 16 2021 10:42:56 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | ICE candidate received: candidate:2403387858 1 tcp 1518280447 10.XX.XX.XX 9 typ host tcptype active generation 0 ufrag c/YU network-id 2 network-cost 50
LoggerFactory.js:100 Mon Aug 16 2021 10:42:56 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | ICE candidate received: candidate:1108738981 1 tcp 1518214911 192.XXX.X.X 9 typ host tcptype active generation 0 ufrag c/YU network-id 1 network-cost 10
LoggerFactory.js:100 Mon Aug 16 2021 10:42:56 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | RTCIceGatheringState changed: complete
LoggerFactory.js:100 Mon Aug 16 2021 10:42:56 GMT+0700 (Western Indonesia Time) | sip.transport | sending WebSocket message:
INVITE sip:+6282311XXXXXX @domain_name SIP/2.0
Via: SIP/2.0/WSS asv5il0mh6sc.invalid;branch=z9hG4bK4035596
Max-Forwards: 70
To: <sip:+6282311XXXXXX @domain_name>
From: “webrtc” <sip:500 @domain_name>;tag=t9cuh03rp3
Call-ID: eq07e6in98hmjs1uulas
CSeq: 8516 INVITE
Contact: <sip:tfqbf6kb @asv5il0mh6sc.invalid;transport=ws;ob>
Allow: ACK,CANCEL,INVITE,MESSAGE,BYE,OPTIONS,INFO,NOTIFY,REFER
Supported: outbound
User-Agent: SIP.js/0.13.6
Content-Type: application/sdp
Content-Length: 6891
v=0
s=-
t=0 0
a=group:BUNDLE 0 1
m=audio 63469 UDP/TLS/RTP/SAVPF 111 103 104 9 0 8 106 105 13 110 112 113 126
c=IN IP4 10.XX.XX.XX
a=candidate:3250795810 1 udp 2122260223 10.XX.XX.XX 63469 typ host generation 0 network-id 2 network-cost 50
a=candidate:211156821 1 udp 2122194687 192.XXX.X.X 50637 typ host generation 0 network-id 1 network-cost 10
a=candidate:2403387858 1 tcp 1518280447 10.XX.XX.XX 9 typ host tcptype active generation 0 network-id 2 network-cost 50
a=candidate:1108738981 1 tcp 1518214911 192.XXX.X.X 9 typ host tcptype active generation 0 network-id 1 network-cost 10
a=ice-ufrag:c/YU
a=setup:actpass
a=mid:0
- List item
a=sendrecv
a=rtcp-mux
a=rtpmap:13 CN/8000
m=video 55429 UDP/TLS/RTP/SAVPF 96 97 98 99 100 101 102 121 127 120 125 107 108 109 35 36 124 119 123 118 114 115 116
a=candidate:3250795810 1 udp 2122260223 10.XX.XX.XX 55429 typ host generation 0 network-id 2 network-cost 50
a=candidate:211156821 1 udp 2122194687 192.XXX.X.X 50147 typ host generation 0 network-id 1 network-cost 10
a=ice-ufrag:c/YU
a=setup:actpass
a=mid:1
a=extmap:14 urn:ietf:params:rtp-hdrext:toffset
a=sendrecv
a=rtcp-mux
a=rtcp-rsize
a=rtcp-fb:96 nack
a=fmtp:97 apt=96
a=rtcp-fb:98 nack
a=fmtp:99 apt=98
a=rtcp-fb:100 nack
a=fmtp:101 apt=100
a=rtcp-fb:102 nack
a=fmtp:121 apt=102
a=rtcp-fb:127 nack
a=fmtp:120 apt=127
a=rtcp-fb:125 nack
a=fmtp:107 apt=125
a=rtcp-fb:108 nack
a=fmtp:109 apt=108
a=rtcp-fb:35 nack
a=fmtp:36 apt=35
a=rtcp-fb:124 nack
a=fmtp:119 apt=124
a=rtcp-fb:123 nack
a=fmtp:118 apt=123
a=fmtp:115 apt=114
LoggerFactory.js:100 Mon Aug 16 2021 10:42:56 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | ICE candidate gathering complete
LoggerFactory.js:100 Mon Aug 16 2021 10:42:56 GMT+0700 (Western Indonesia Time) | sip.transport | received WebSocket text message:
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/WSS asv5il0mh6sc.invalid;branch=z9hG4bK4035596;rport=43402;received=127.0.0.1
To: <sip:+6282311XXXXXX @domain_name>;tag=a2d3384ccaf3d0890b1d994026562a34.429c0000
CSeq: 8516 INVITE
Proxy-Authenticate: Digest realm=“domain_name”, nonce=“YRnf9GEZ3shCY5HMSWfzE6ctJ5ig1Kd7”
Server: kamailio (5.5.0 (x86_64/linux))
Content-Length: 0
ACK sip:+6282311XXXXXX @domain_name SIP/2.0
Via: SIP/2.0/WSS asv5il0mh6sc.invalid;branch=z9hG4bK7163476
Max-Forwards: 70
CSeq: 8516 ACK
Supported: outbound
Content-Length: 0
Via: SIP/2.0/WSS asv5il0mh6sc.invalid;branch=z9hG4bK6711062
Max-Forwards: 70
CSeq: 8517 INVITE
Proxy-Authorization: Digest algorithm=MD5, username=“500”, realm=“domain_name”, nonce=“YRnf9GEZ3shCY5HMSWfzE6ctJ5ig1Kd7”, uri=“sip:+6282311XXXXXX@domain_name”, response=“da7c3cf9c21d8aa85f72c5e723f8d42c”
Supported: outbound
v=0
s=-
t=0 0
a=group:BUNDLE 0 1
a=ice-ufrag:c/YU
a=setup:actpass
a=mid:0
a=sendrecv
a=rtcp-mux
a=rtpmap:13 CN/8000
a=ice-ufrag:c/YU
a=setup:actpass
a=mid:1
a=sendrecv
a=rtcp-mux
a=rtcp-rsize
a=rtcp-fb:96 nack
a=fmtp:97 apt=96
a=rtcp-fb:98 nack
a=fmtp:99 apt=98
a=rtcp-fb:100 nack
a=fmtp:101 apt=100
a=rtcp-fb:102 nack
a=fmtp:121 apt=102
a=rtcp-fb:127 nack
a=fmtp:120 apt=127
a=rtcp-fb:125 nack
a=fmtp:107 apt=125
a=rtcp-fb:108 nack
a=fmtp:109 apt=108
a=rtcp-fb:35 nack
a=fmtp:36 apt=35
a=rtcp-fb:124 nack
a=fmtp:119 apt=124
a=rtcp-fb:123 nack
a=fmtp:118 apt=123
a=fmtp:115 apt=114
SIP/2.0 100 trying – your call is important to us
Via: SIP/2.0/WSS asv5il0mh6sc.invalid;branch=z9hG4bK6711062;rport=43402;received=127.0.0.1
CSeq: 8517 INVITE
Content-Length: 0
LoggerFactory.js:100 Mon Aug 16 2021 10:42:56 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | ICE Connection State changed to iceConnectionChecking
SIP/2.0 500 Server Internal Error
Via: SIP/2.0/WSS asv5il0mh6sc.invalid;branch=z9hG4bK6711062;received=127.0.0.1;rport=43402
To: sip:+6282311XXXXXX@domain_name;tag=23r36zzp
CSeq: 8517 INVITE
Warning: 399 03077.08860.B.005.422.228.0.15.01039.00000000.00000 “SDP body length beyond limit”
Content-Length: 0
Via: SIP/2.0/WSS asv5il0mh6sc.invalid;branch=z9hG4bK2860365
Max-Forwards: 70
To: <sip:+6282311XXXXXX @domain_name>;tag=23r36zzp
CSeq: 8517 ACK
Supported: outbound
Content-Length: 0
LoggerFactory.js:100 Mon Aug 16 2021 10:42:56 GMT+0700 (Western Indonesia Time) | sip.inviteclientcontext | closing INVITE session eq07e6in98hmjs1uulast9cuh03rp3
LoggerFactory.js:100 Mon Aug 16 2021 10:42:56 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | closing PeerConnection
LoggerFactory.js:100 Mon Aug 16 2021 10:42:56 GMT+0700 (Western Indonesia Time) | sip.invitecontext.sessionDescriptionHandler | resetIceGatheringComplete
