tahapnya sudah saya install add ons webconferencenya versi 2.2.0-5
email service sudah disetting dan sudah jalan servicenya , im service juga sudah.
untuk codec video juga sudah di check.
nah pada saat create web conference room sudah berhasil terkirim ke email peserta namun pada saat di clik link untuk masuk ke web login responnya blank saja.
baru jalankan locate di atas. Kalo misal ndak ada install package yang diperlukan. Untuk mencari nama package yang mengandung file di atas bisa dengan:
updates: mirror.dionipe.net
Excluding Packages from CentOS-5 - Addons
Finished
Excluding Packages from CentOS-5 - Base
Finished
Excluding Packages from CentOS-5 - Extras
Finished
Excluding Packages from CentOS-5 - Updates
Finished
LowayResearch/filelists | 46 kB 00:00
commercial-addons/filelists | 341 kB 00:03
elastix-extras/filelists | 338 kB 00:06
elastix-updates/filelists | 1.3 MB 00:17
epel/filelists_db | 3.8 MB 00:06
iperfex/filelists | 7.3 kB 00:00
pgdg91/filelists_db | 127 kB 00:01
updates/filelists_db | 3.8 MB 00:06
elastix-2.0.0-9.noarch : Elastix is a Web based software to administrate a PBX
: based in open source programs
Repo : elastix-base
Matched from:
Filename : /var/www/html/libs/xajax/xajax.inc.php
elastix-framework-2.4.0-18.noarch : Elastix is a Web based software to
…: administrate a PBX based in open source programs
Repo : elastix-updates
Matched from:
elastix-framework-2.5.0-2.noarch : Elastix is a Web based software to
Matched from:
elastix-framework-2.4.0-17.noarch : Elastix is a Web based software to
Matched from:
elastix-framework-2.4.0-12.noarch : Elastix is a Web based software to
Matched from:
elastix-framework-2.4.0-19.noarch : Elastix is a Web based software to
Matched from:
elastix-framework-2.4.0-16.noarch : Elastix is a Web based software to
Matched from:
elastix-framework-2.4.0-15.noarch : Elastix is a Web based software to
Matched from:
elastix-framework-2.5.0-1.noarch : Elastix is a Web based software to
Matched from:
sahana-0.6.3-1.el5.noarch : Sahana is a free open source disaster management
: application
Repo : epel
Matched from:
Filename : /usr/share/sahana/3rd/xajax/xajax.inc.php
setelah di cek masih belum ada ya filenya, apa dicreate sendiri aja atau bagaimana ya om…
Jadi itu kan muncul nama package nya yg perlu diinstall. Sori saya kurang lengkap. Yg paling baru adalah elastix-framework-2.5.0-1.noarch. kalo sudah ketemu jalankan:
saya pikir frame worknya ketinggian karena udah elastix-framework.noarch 2.5.0-17 , Nah dengan sok taunya saya akhirnya saya hapus dulu elastix-frameworknya yang 2.5.0-17 ga taunya malah makin brantakan hehehehe
setelah saya install yang 2.5.0.1 nya dashboarnya ga ada menu pbxnya, dan saya sudah balikin lagi ke 2.5.0-17 sama juga engga ada menunya passwordnya pun yang lama engga bisa masuk om
saya coba restart password admin jadi password pash masuk jeng jeng sama juga engga ada menu pbxnya. kaya gini tampilannya om
kalo bgini kira2 gimana ya om balikin ke awal, kalo engga bisa brati harus install ulang ya om…
trus kalo mau install ulang boleh dikasih reference ga om pakai elastix brapa dll untuk bisa webconferencenya, atau disto yang lain yang om implement web conf nya jalan.
Total size: 10 M
Downloading Packages:
Running rpm_check_debug
Running Transaction Test
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
0:group asterisk already present
Installing : elastix-framework 1/1
error reading information on service mariadb: No such file or directory
The key amiadminpwd already exist in /etc/elastix.conf… Nothing to do
File /etc/amportal.conf does not exist…Nothing to do
Restarting amportal…
