bagaimana konfigurasi di sip.conf untuk 2 user membuat TLS nya ?
Coba ikutin tutorial ini pak : Asterisk Secure Calling Tutorial
saya sudah coba ikuti tutorial di link tersebut,tapi hanya untuk 1 user seperti berikut misalnya
tlsenable=yes
tlsbindaddr=0.0.0.0
tlscertfile=/etc/asterisk/keys/asterisk.pem
tlscafile=/etc/asterisk/keys/ca.crt
tlscipher=ALL
tlsclientmethod=tlsv1 ;none of the others seem to work with Blink as the client
apakah kalau 2 user di buat seperti ini misalnya
tlsenable=yes
tlsbindaddr=0.0.0.0
tlscertfile=/etc/asterisk/keys1/asterisk.pem
tlscafile=/etc/asterisk/keys1/ca.crt
tlscipher=ALL
tlsenable=yes
tlsbindaddr=0.0.0.0
tlscertfile=/etc/asterisk/keys2/asterisk.pem
tlscafile=/etc/asterisk/keys2/ca.crt
tlscipher=ALL
Di sip.conf cukup 1 config TLS saja :
tlsenable=yes
tlsbindaddr=0.0.0.0
tlscipher=ALL
Tapi bikin customer cert nya menggunakan key server itu, perhatikan ini :
./ast_tls_cert -m client -c /etc/asterisk/keys/ca.crt -k /etc/asterisk/keys/ca.key -C phone1.mycompany.com -O "My Super Company" -d /etc/asterisk/keys -o malcolm
- The “-m client” option tells the script that we want a client certificate, not a server certificate.
- The “-c /etc/asterisk/keys/ca.crt” option specifies which Certificate Authority (ourselves) that we’re using.
- The “-k /etc/asterisk/keys/ca.key” provides the key for the above-defined Certificate Authority.
- The “-C” option, since we’re defining a client this time, is used to define the hostname or IP address of our SIP phone
- The “-O” option defines our organizational name.
- The “-d” option is the output directory of the keys."
- The “-o” option is the name of the key we’re outputting.
-C itu bisa menggunakan alamat IP Address si UserA misalnya
-d lokasi tempat certifcatenya untuk si UserA tersebut, dimana rekomendasinya disamakan dengan lokasi cert server
- o untuk nama certificatenya misalnya userA, userB, jadi nanti ada file :
userA.crt
userA.csr
userA.key
UserA.pem
userB.crt
userB.csr
userB.key
UserB.pem
kalau di extentention.conf nya ada tambahan gak ? masalahnya melakukan panggilan sesama client yang menggunakan TLS tidak bisa
saya buat seperti ini jadinya
[ilham]
exten => 100,1,Dial(SIP/100)
exten => 100,2,Hangup ()
exten => 101,1,Dial(SIP/101)
exten => 101,2,Hangup ()
Di extensions.conf tidak ada tambahan, TLS di level SIP nya.
Coba debug saja, perhatikan errornya dimana pada saat dial tersebut.
setelah saya debug error disini mas
chan_sip.c:3641 retrans_pkt: Retransmission timeout reached on transmission 2e69697e4e3c5e571644b3686c1c35e9@172.16.23.5:5060 for seqno 102 (Non-critical Request) – See https://wiki.asterisk.org/wiki/display/AST/SIP+Retransmissions
permisi mas, mau tanya nih,
tentang konfigurasi yg untuk client cert dan server cert TLS di asterisk.
untuk opsi -C yang di command membuat client cert nya itu diisi ip client atau ip server seperti pada -C yang ada di perintah membuat server cert ya ?
terimakasih
based on https://wiki.asterisk.org/wiki/display/AST/Secure+Calling+Tutorial
permisi saya mau tanya. saya lagi nyobain bikin tls tapi error waktu mau regis sip client nya dengan error seperti ini
root@denny-K43SJ:/etc/asterisk# tail -f /var/log/asterisk/messages | tee debug1.txt
[Jun 2 14:20:09] ERROR[3161] pjsip: ssl0x7efbf4000 Error loading certificate chain file ‘/etc/asterisk/keys3/asterisk.crt’
mohon bantuannya terimakasih
