Tidak mau restart asterisk
Pak mau tanya pada saat aku mau restart Asterisk yang aku install di openwrt yang muncul ini pak :
"Segmentation fault"
tidak mau restart asterisknya pak.
Mohon bantuanya…
asterisknya sudah tidak up juga mungkin, coba cek :
ps ax |grep asterisk
Muncul running asterisk atau tidak. Lalu cek juga errornya karena apa dengan cara :
dmesg
root@OpenWrt:/etc/asterisk# ps ax |grep asterisk
1673 root 868 R grep asterisk
root@OpenWrt:/etc/asterisk# dmesg
Linux version 2.6.31.10 (maris@bumba) (gcc version 4.3.3 (GCC) ) #1 Tue Apr 13 10:46:14 EEST 2010
CPU revision is: 0001800a (MIPS 4Kc)
Determined physical RAM map:
User-defined physical RAM map:
memory: 01800000 @ 00000000 (usable)
Initrd not found or empty - disabling initrd
Zone PFN ranges:
Normal 0x00000000 -> 0x00001800
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0x00000000 -> 0x00001800
On node 0 totalpages: 6144
free_area_init_node: node 0, pgdat c031dba0, node_mem_map c1000000
Normal zone: 48 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 6096 pages, LIFO batch:0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 6096
Kernel command line: init=/etc/preinit console=hvc0 board=vm mem=24M
PID hash table entries: 128 (order: 7, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Memory: 20924k/24576k available (1881k kernel code, 3652k reserved, 287k data, 120k init, 0k highmem)
NR_IRQS:128
console [hvc0] enabled
Calibrating delay loop… 382.97 BogoMIPS (lpj=765952)
Itu asterisknya memang sudah tidak running, coba jalankan dahulu manual :
asterisk -vvvc
Lihat apakah masuk ke asterisk cli atau langsung exit ?
