avaya call masuk, cuma freePBX ke avaya gk masuk gan :
ini lognya :
Connected to Asterisk 13.14.0 currently running on localhost (pid = 1936)
– Executing [8005@from-trunk:1] GotoIf(“OOH323/avaya-21”, “1?ext-local,8005,1:followme-check,8005,1”) in new stack
– Goto (ext-local,8005,1)
– Executing [8005@ext-local:1] Set(“OOH323/avaya-21”, “__RINGTIMER=15”) in new stack
– Executing [8005@ext-local:2] Macro(“OOH323/avaya-21”, “exten-vm,novm,8005,0,0,0”) in new stack
– Executing [s@macro-exten-vm:1] Macro(“OOH323/avaya-21”, “user-callerid,”) in new stack
– Executing [s@macro-user-callerid:1] Set(“OOH323/avaya-21”, “TOUCH_MONITOR=1491791731.24”) in new stack
– Executing [s@macro-user-callerid:2] Set(“OOH323/avaya-21”, “AMPUSER=”) in new stack
– Executing [s@macro-user-callerid:3] GotoIf(“OOH323/avaya-21”, “0?report”) in new stack
– Executing [s@macro-user-callerid:4] ExecIf(“OOH323/avaya-21”, “1?Set(REALCALLERIDNUM=)”) in new stack
– Executing [s@macro-user-callerid:5] Set(“OOH323/avaya-21”, “AMPUSER=”) in new stack
– Executing [s@macro-user-callerid:6] GotoIf(“OOH323/avaya-21”, “0?limit”) in new stack
– Executing [s@macro-user-callerid:7] Set(“OOH323/avaya-21”, “AMPUSERCIDNAME=”) in new stack
– Executing [s@macro-user-callerid:8] GotoIf(“OOH323/avaya-21”, “1?report”) in new stack
– Goto (macro-user-callerid,s,15)
– Executing [s@macro-user-callerid:15] GotoIf(“OOH323/avaya-21”, “0?continue”) in new stack
– Executing [s@macro-user-callerid:16] ExecIf(“OOH323/avaya-21”, “1?Set(__CALLEE_ACCOUNCODE=)”) in new stack
– Executing [s@macro-user-callerid:17] Set(“OOH323/avaya-21”, “__TTL=64”) in new stack
– Executing [s@macro-user-callerid:18] GotoIf(“OOH323/avaya-21”, “1?continue”) in new stack
– Goto (macro-user-callerid,s,29)
– Executing [s@macro-user-callerid:29] Set(“OOH323/avaya-21”, “CALLERID(number)=”) in new stack
– Executing [s@macro-user-callerid:30] Set(“OOH323/avaya-21”, “CALLERID(name)=”) in new stack
– Executing [s@macro-user-callerid:31] GotoIf(“OOH323/avaya-21”, “1?cnum”) in new stack
– Goto (macro-user-callerid,s,33)
– Executing [s@macro-user-callerid:33] Set(“OOH323/avaya-21”, “CDR(cnum)=”) in new stack
[2017-04-10 09:35:31] WARNING[1960]: func_cdr.c:383 cdr_write_callback: CDR requires a value (CDR(variable)=value)
– Executing [s@macro-user-callerid:34] Set(“OOH323/avaya-21”, “CHANNEL(language)=en”) in new stack
– Executing [s@macro-exten-vm:2] Set(“OOH323/avaya-21”, “RingGroupMethod=none”) in new stack
– Executing [s@macro-exten-vm:3] Set(“OOH323/avaya-21”, “__EXTTOCALL=8005”) in new stack
– Executing [s@macro-exten-vm:4] Set(“OOH323/avaya-21”, “__PICKUPMARK=8005”) in new stack
– Executing [s@macro-exten-vm:5] Set(“OOH323/avaya-21”, “RT=”) in new stack
[2017-04-10 09:35:31] WARNING[16277][C-00000018]: chan_sip.c:22827 func_header_read: This function can only be used on SIP channels.
– Executing [s@macro-exten-vm:6] ExecIf(“OOH323/avaya-21”, “0?Macro(vm,novm,DIRECTDIAL,)”) in new stack
– Executing [s@macro-exten-vm:7] ExecIf(“OOH323/avaya-21”, “0?MacroExit()”) in new stack
– Executing [s@macro-exten-vm:8] Gosub(“OOH323/avaya-21”, “sub-record-check,s,1(exten,8005,dontcare)”) in new stack
– Executing [s@sub-record-check:1] GotoIf(“OOH323/avaya-21”, “0?initialized”) in new stack
– Executing [s@sub-record-check:2] Set(“OOH323/avaya-21”, “__REC_STATUS=INITIALIZED”) in new stack
– Executing [s@sub-record-check:3] Set(“OOH323/avaya-21”, “NOW=1491791731”) in new stack
– Executing [s@sub-record-check:4] Set(“OOH323/avaya-21”, “__DAY=10”) in new stack
– Executing [s@sub-record-check:5] Set(“OOH323/avaya-21”, “__MONTH=04”) in new stack
– Executing [s@sub-record-check:6] Set(“OOH323/avaya-21”, “__YEAR=2017”) in new stack
– Executing [s@sub-record-check:7] Set(“OOH323/avaya-21”, “__TIMESTR=20170410-093531”) in new stack
– Executing [s@sub-record-check:8] Set(“OOH323/avaya-21”, “__FROMEXTEN=unknown”) in new stack
– Executing [s@sub-record-check:9] Set(“OOH323/avaya-21”, “__MON_FMT=wav”) in new stack
– Executing [s@sub-record-check:10] NoOp(“OOH323/avaya-21”, “Recordings initialized”) in new stack
– Executing [s@sub-record-check:11] ExecIf(“OOH323/avaya-21”, “0?Set(ARG3=dontcare)”) in new stack
– Executing [s@sub-record-check:12] Set(“OOH323/avaya-21”, “REC_POLICY_MODE_SAVE=”) in new stack
– Executing [s@sub-record-check:13] ExecIf(“OOH323/avaya-21”, “0?Set(REC_STATUS=NO)”) in new stack
– Executing [s@sub-record-check:14] GotoIf(“OOH323/avaya-21”, “5?checkaction”) in new stack
– Goto (sub-record-check,s,17)
– Executing [s@sub-record-check:17] GotoIf(“OOH323/avaya-21”, “1?sub-record-check,exten,1”) in new stack
– Goto (sub-record-check,exten,1)
– Executing [exten@sub-record-check:1] NoOp(“OOH323/avaya-21”, “Exten Recording Check between unknown and 8005”) in new stack
– Executing [exten@sub-record-check:2] Set(“OOH323/avaya-21”, “CALLTYPE=internal”) in new stack
– Executing [exten@sub-record-check:3] ExecIf(“OOH323/avaya-21”, “0?Set(CALLTYPE=)”) in new stack
– Executing [exten@sub-record-check:4] Set(“OOH323/avaya-21”, “CALLEE=dontcare”) in new stack
– Executing [exten@sub-record-check:5] ExecIf(“OOH323/avaya-21”, “0?Set(CALLEE=dontcare)”) in new stack
– Executing [exten@sub-record-check:6] GotoIf(“OOH323/avaya-21”, “0?callee”) in new stack
– Executing [exten@sub-record-check:7] GotoIf(“OOH323/avaya-21”, “1?caller”) in new stack
– Goto (sub-record-check,exten,13)
– Executing [exten@sub-record-check:13] Set(“OOH323/avaya-21”, “RECMODE=”) in new stack
– Executing [exten@sub-record-check:14] ExecIf(“OOH323/avaya-21”, “1?Set(RECMODE=dontcare)”) in new stack
– Executing [exten@sub-record-check:15] ExecIf(“OOH323/avaya-21”, “1?Set(RECMODE=dontcare)”) in new stack
– Executing [exten@sub-record-check:16] Gosub(“OOH323/avaya-21”, “recordcheck,1(dontcare,internal,8005)”) in new stack
– Executing [recordcheck@sub-record-check:1] NoOp(“OOH323/avaya-21”, “Starting recording check against dontcare”) in new stack
– Executing [recordcheck@sub-record-check:2] Goto(“OOH323/avaya-21”, “dontcare”) in new stack
– Goto (sub-record-check,recordcheck,3)
– Executing [recordcheck@sub-record-check:3] Return(“OOH323/avaya-21”, “”) in new stack
– Executing [exten@sub-record-check:17] Return(“OOH323/avaya-21”, “”) in new stack
– Executing [s@macro-exten-vm:9] GotoIf(“OOH323/avaya-21”, “1?macrodial”) in new stack
– Goto (macro-exten-vm,s,15)
– Executing [s@macro-exten-vm:15] GosubIf(“OOH323/avaya-21”, “0?clrheader,1()”) in new stack
– Executing [s@macro-exten-vm:16] Macro(“OOH323/avaya-21”, “dial-one,Ttr,8005”) in new stack
– Executing [s@macro-dial-one:1] Set(“OOH323/avaya-21”, “DEXTEN=8005”) in new stack
– Executing [s@macro-dial-one:2] ExecIf(“OOH323/avaya-21”, “0?Set(EXTTOCALL=8005)”) in new stack
– Executing [s@macro-dial-one:3] Set(“OOH323/avaya-21”, “DIALSTATUS_CW=”) in new stack
– Executing [s@macro-dial-one:4] GosubIf(“OOH323/avaya-21”, “0?screen,1()”) in new stack
– Executing [s@macro-dial-one:5] GosubIf(“OOH323/avaya-21”, “0?cf,1()”) in new stack
– Executing [s@macro-dial-one:6] GotoIf(“OOH323/avaya-21”, “1?skip1”) in new stack
– Goto (macro-dial-one,s,9)
– Executing [s@macro-dial-one:9] GotoIf(“OOH323/avaya-21”, “0?nodial”) in new stack
– Executing [s@macro-dial-one:10] GotoIf(“OOH323/avaya-21”, “0?continue”) in new stack
– Executing [s@macro-dial-one:11] Set(“OOH323/avaya-21”, “EXTHASCW=ENABLED”) in new stack
– Executing [s@macro-dial-one:12] GotoIf(“OOH323/avaya-21”, “0?next1:cwinusebusy”) in new stack
– Goto (macro-dial-one,s,24)
– Executing [s@macro-dial-one:24] GotoIf(“OOH323/avaya-21”, “0?next3:continue”) in new stack
– Goto (macro-dial-one,s,26)
– Executing [s@macro-dial-one:26] GotoIf(“OOH323/avaya-21”, “0?nodial”) in new stack
– Executing [s@macro-dial-one:27] GosubIf(“OOH323/avaya-21”, “1?dstring,1():dlocal,1()”) in new stack
– Executing [dstring@macro-dial-one:1] Set(“OOH323/avaya-21”, “DSTRING=”) in new stack
– Executing [dstring@macro-dial-one:2] Set(“OOH323/avaya-21”, “DEVICES=8005”) in new stack
– Executing [dstring@macro-dial-one:3] ExecIf(“OOH323/avaya-21”, “0?Return()”) in new stack
– Executing [dstring@macro-dial-one:4] ExecIf(“OOH323/avaya-21”, “0?Set(DEVICES=005)”) in new stack
– Executing [dstring@macro-dial-one:5] Set(“OOH323/avaya-21”, “LOOPCNT=1”) in new stack
– Executing [dstring@macro-dial-one:6] Set(“OOH323/avaya-21”, “ITER=1”) in new stack
– Executing [dstring@macro-dial-one:7] Set(“OOH323/avaya-21”, “THISDIAL=PJSIP/8005”) in new stack
– Executing [dstring@macro-dial-one:8] GosubIf(“OOH323/avaya-21”, “1?zap2dahdi,1()”) in new stack
– Executing [zap2dahdi@macro-dial-one:1] ExecIf(“OOH323/avaya-21”, “0?Return()”) in new stack
– Executing [zap2dahdi@macro-dial-one:2] Set(“OOH323/avaya-21”, “NEWDIAL=”) in new stack
– Executing [zap2dahdi@macro-dial-one:3] Set(“OOH323/avaya-21”, “LOOPCNT2=1”) in new stack
– Executing [zap2dahdi@macro-dial-one:4] Set(“OOH323/avaya-21”, “ITER2=1”) in new stack
– Executing [zap2dahdi@macro-dial-one:5] Set(“OOH323/avaya-21”, “THISPART2=PJSIP/8005”) in new stack
– Executing [zap2dahdi@macro-dial-one:6] ExecIf(“OOH323/avaya-21”, “0?Set(THISPART2=DAHDIIP/8005)”) in new stack
– Executing [zap2dahdi@macro-dial-one:7] Set(“OOH323/avaya-21”, “NEWDIAL=PJSIP/8005&”) in new stack
– Executing [zap2dahdi@macro-dial-one:8] Set(“OOH323/avaya-21”, “ITER2=2”) in new stack
– Executing [zap2dahdi@macro-dial-one:9] GotoIf(“OOH323/avaya-21”, “0?begin2”) in new stack
– Executing [zap2dahdi@macro-dial-one:10] Set(“OOH323/avaya-21”, “THISDIAL=PJSIP/8005”) in new stack
– Executing [zap2dahdi@macro-dial-one:11] Return(“OOH323/avaya-21”, “”) in new stack
– Executing [dstring@macro-dial-one:9] GotoIf(“OOH323/avaya-21”, “0?docheck”) in new stack
– Executing [dstring@macro-dial-one:10] NoOp(“OOH323/avaya-21”, “Debug: Found PJSIP Destination PJSIP/8005”) in new stack
– Executing [dstring@macro-dial-one:11] GotoIf(“OOH323/avaya-21”, “0?doset”) in new stack
– Executing [dstring@macro-dial-one:12] NoOp(“OOH323/avaya-21”, “Debug: Updating PJSIP Destination with PJSIP_DIAL_CONTACTS”) in new stack
– Executing [dstring@macro-dial-one:13] Set(“OOH323/avaya-21”, “THISDIAL=”) in new stack
– Executing [dstring@macro-dial-one:14] GotoIf(“OOH323/avaya-21”, “1?skipset”) in new stack
– Goto (macro-dial-one,dstring,16)
– Executing [dstring@macro-dial-one:16] Set(“OOH323/avaya-21”, “ITER=2”) in new stack
– Executing [dstring@macro-dial-one:17] GotoIf(“OOH323/avaya-21”, “0?begin”) in new stack
– Executing [dstring@macro-dial-one:18] ExecIf(“OOH323/avaya-21”, “1?Return()”) in new stack
– Executing [s@macro-dial-one:28] GotoIf(“OOH323/avaya-21”, “1?nodial”) in new stack
– Goto (macro-dial-one,s,56)
– Executing [s@macro-dial-one:56] ExecIf(“OOH323/avaya-21”, “1?Set(DIALSTATUS=NOANSWER)”) in new stack
– Executing [s@macro-dial-one:57] NoOp(“OOH323/avaya-21”, “Returned from dial-one with nothing to call and DIALSTATUS: NOANSWER”) in new stack
– Executing [s@macro-dial-one:58] MacroExit(“OOH323/avaya-21”, “”) in new stack
– Executing [s@macro-exten-vm:17] Set(“OOH323/avaya-21”, “SV_DIALSTATUS=NOANSWER”) in new stack
– Executing [s@macro-exten-vm:18] GosubIf(“OOH323/avaya-21”, “0?docfu,1()”) in new stack
– Executing [s@macro-exten-vm:19] GosubIf(“OOH323/avaya-21”, “0?docfb,1()”) in new stack
– Executing [s@macro-exten-vm:20] Set(“OOH323/avaya-21”, “DIALSTATUS=NOANSWER”) in new stack
– Executing [s@macro-exten-vm:21] ExecIf(“OOH323/avaya-21”, “0?MacroExit()”) in new stack
– Executing [s@macro-exten-vm:22] GotoIf(“OOH323/avaya-21”, “1?s-NOANSWER,1”) in new stack
– Goto (macro-exten-vm,s-NOANSWER,1)
– Executing [s-NOANSWER@macro-exten-vm:1] GotoIf(“OOH323/avaya-21”, “0?exit,1”) in new stack
– Executing [s-NOANSWER@macro-exten-vm:2] PlayTones(“OOH323/avaya-21”, “congestion”) in new stack
[2017-04-10 09:35:31] WARNING[16277][C-00000018]: channel.c:5630 set_format: Unable to find a codec translation path: (slin) -> (g729)
[2017-04-10 09:35:31] WARNING[16277][C-00000018]: indications.c:156 playtones_alloc: Unable to set ‘OOH323/avaya-21’ to signed linear format (write)
[2017-04-10 09:35:31] NOTICE[16277][C-00000018]: app_playtones.c:100 handle_playtones: Unable to start playtones
== Spawn extension (macro-exten-vm, s-NOANSWER, 2) exited non-zero on ‘OOH323/avaya-21’ in macro ‘exten-vm’
== Spawn extension (ext-local, 8005, 2) exited non-zero on ‘OOH323/avaya-21’
– Executing [h@ext-local:1] Macro(“OOH323/avaya-21”, “hangupcall,”) in new stack
– Executing [s@macro-hangupcall:1] GotoIf(“OOH323/avaya-21”, “1?theend”) in new stack
– Goto (macro-hangupcall,s,3)
– Executing [s@macro-hangupcall:3] ExecIf(“OOH323/avaya-21”, “0?Set(CDR(recordingfile)=)”) in new stack
– Executing [s@macro-hangupcall:4] Hangup(“OOH323/avaya-21”, “”) in new stack
== Spawn extension (macro-hangupcall, s, 4) exited non-zero on ‘OOH323/avaya-21’ in macro ‘hangupcall’
== Spawn extension (ext-local, h, 1) exited non-zero on ‘OOH323/avaya-21’
[2017-04-10 09:35:33] ERROR[16276]: chan_ooh323.c:1621 ooh323_set_write_format: No owner found
