mungkin ada yang bisa bantu rekan2
cc pak @anton @asoka @godril
saya tidak bisa nelepon keluar menggunakan SPA3102, tapi untuk incomingnya udah berhasil dari PSTN
menggunakan Briker 2.0 Luwak untuk IPPBX nya
berikut saya sertakan confignya
SPA3102
Trunk di Briker
OutboundRouter di Briker
log di asterisk
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [902220660173@from-internal:1] Macro(“SIP/212-00000033”, “user-callerid,SKIPTTL,”) in new stack
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-user-callerid:1] NoOp(“SIP/212-00000033”, “user-callerid: device 212”) in new stack
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-user-callerid:2] Set(“SIP/212-00000033”, “AMPUSER=212”) in new stack
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-user-callerid:3] GotoIf(“SIP/212-00000033”, “0?report”) in new stack
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-user-callerid:4] ExecIf(“SIP/212-00000033”, “1?Set(REALCALLERIDNUM=212)”) in new stack
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-user-callerid:5] NoOp(“SIP/212-00000033”, “REALCALLERIDNUM is 212”) in new stack
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-user-callerid:6] Set(“SIP/212-00000033”, “AMPUSER=212”) in new stack
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-user-callerid:7] Set(“SIP/212-00000033”, “AMPUSERCIDNAME=VoIP Test”) in new stack
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-user-callerid:8] GotoIf(“SIP/212-00000033”, “0?report”) in new stack
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-user-callerid:9] Set(“SIP/212-00000033”, “AMPUSERCID=212”) in new stack
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-user-callerid:10] Set(“SIP/212-00000033”, “CALLERID(all)=“VoIP Test” <212>”) in new stack
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-user-callerid:11] Set(“SIP/212-00000033”, “REALCALLERIDNUM=212”) in new stack
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-user-callerid:12] ExecIf(“SIP/212-00000033”, “0?Set(CHANNEL(language)=)”) in new stack
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-user-callerid:13] NoOp(“SIP/212-00000033”, “TTL: ARG1: SKIPTTL”) in new stack
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-user-callerid:14] GotoIf(“SIP/212-00000033”, “1?continue”) in new stack
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx_builtins.c: Goto (macro-user-callerid,s,23)
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-user-callerid:23] NoOp(“SIP/212-00000033”, “Using CallerID “VoIP Test” <212>”) in new stack
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [902220660173@from-internal:2] Set(“SIP/212-00000033”, “_NODEST=”) in new stack
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [902220660173@from-internal:3] Macro(“SIP/212-00000033”, “record-enable,212,OUT,”) in new stack
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-record-enable:1] GotoIf(“SIP/212-00000033”, “0?2:4”) in new stack
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx_builtins.c: Goto (macro-record-enable,s,4)
[May 22 07:37:11] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-record-enable:4] AGI(“SIP/212-00000033”, “recordingcheck,20170522-073711,BrikerIPPBX-1495413431.97”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/recordingcheck
[May 22 07:37:12] VERBOSE[3128][C-0000001f] res_agi.c: recordingcheck,20170522-073711,BrikerIPPBX-1495413431.97: Outbound recording not enabled
[May 22 07:37:12] VERBOSE[3128][C-0000001f] res_agi.c: <SIP/212-00000033>AGI Script recordingcheck completed, returning 0
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-record-enable:5] NoOp(“SIP/212-00000033”, “No recording needed”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [902220660173@from-internal:4] Macro(“SIP/212-00000033”, “dialout-trunk,6,02220660173,”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:1] Set(“SIP/212-00000033”, “ENTEREDEXT=”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:2] NoOp(“SIP/212-00000033”, “DEBUG: BT = CH = SIP/212-00000033”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:3] Set(“SIP/212-00000033”, “BT=”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:4] Set(“SIP/212-00000033”, “BT=”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:5] NoOp(“SIP/212-00000033”, “DEBUG: BT = CID = 212”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:6] GotoIf(“SIP/212-00000033”, “1?authkeylock”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx_builtins.c: Goto (macro-dialout-trunk,s,9)
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:9] Set(“SIP/212-00000033”, “KEYLOCK=”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:10] GotoIf(“SIP/212-00000033”, “0?askpin:pinok”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx_builtins.c: Goto (macro-dialout-trunk,s,13)
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:13] NoOp(“SIP/212-00000033”, “OK”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:14] Set(“SIP/212-00000033”, “DIAL_TRUNK=6”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:15] Set(“SIP/212-00000033”, “ZAP2DAHDI=SIP/telkom2035075”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:16] Set(“SIP/212-00000033”, “VAR1=SIP/”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:17] Set(“SIP/212-00000033”, “VAR2=telkom2035075”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:18] ExecIf(“SIP/212-00000033”, “0?Set(OUT_6=DAHDI/telkom2035075)”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:19] ExecIf(“SIP/212-00000033”, “0?Set(OUT_6=DAHDI/telkom2035075)”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:20] ExecIf(“SIP/212-00000033”, “0?Set(OUT_6=DAHDI/telkom2035075)”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:21] ExecIf(“SIP/212-00000033”, “0?Authenticate()”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:22] GotoIf(“SIP/212-00000033”, “0?disabletrunk,1”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:23] Set(“SIP/212-00000033”, “DIAL_NUMBER=02220660173”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:24] Set(“SIP/212-00000033”, “DIAL_TRUNK_OPTIONS=tTWr”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:25] Set(“SIP/212-00000033”, “GROUP()=OUT_6”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:26] GotoIf(“SIP/212-00000033”, “1?nomax”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx_builtins.c: Goto (macro-dialout-trunk,s,28)
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:28] GotoIf(“SIP/212-00000033”, “0?skipoutcid”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:29] Set(“SIP/212-00000033”, “DIAL_TRUNK_OPTIONS=TW”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:30] Macro(“SIP/212-00000033”, “outbound-callerid,6”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-outbound-callerid:1] ExecIf(“SIP/212-00000033”, “0?Set(CALLERPRES()=)”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-outbound-callerid:2] GotoIf(“SIP/212-00000033”, “1?start”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx_builtins.c: Goto (macro-outbound-callerid,s,4)
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-outbound-callerid:4] NoOp(“SIP/212-00000033”, “REALCALLERIDNUM is 212”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-outbound-callerid:5] GotoIf(“SIP/212-00000033”, “1?normcid”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx_builtins.c: Goto (macro-outbound-callerid,s,10)
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-outbound-callerid:10] Set(“SIP/212-00000033”, “USEROUTCID=”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-outbound-callerid:11] Set(“SIP/212-00000033”, “EMERGENCYCID=”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-outbound-callerid:12] Set(“SIP/212-00000033”, “TRUNKOUTCID=”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-outbound-callerid:13] GotoIf(“SIP/212-00000033”, “1?trunkcid”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx_builtins.c: Goto (macro-outbound-callerid,s,17)
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-outbound-callerid:17] GotoIf(“SIP/212-00000033”, “1?usercid”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx_builtins.c: Goto (macro-outbound-callerid,s,19)
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-outbound-callerid:19] GotoIf(“SIP/212-00000033”, “1?report”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx_builtins.c: Goto (macro-outbound-callerid,s,23)
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-outbound-callerid:23] NoOp(“SIP/212-00000033”, “CallerID set to “VoIP Test” <212>”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:31] AGI(“SIP/212-00000033”, “fixlocalprefix”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/fixlocalprefix
[May 22 07:37:12] VERBOSE[3128][C-0000001f] res_agi.c: <SIP/212-00000033>AGI Script fixlocalprefix completed, returning 0
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:32] Set(“SIP/212-00000033”, “OUTNUM=02220660173”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:33] Set(“SIP/212-00000033”, “REALOUTNUM=02220660173”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:34] GotoIf(“SIP/212-00000033”, “0?askpin1:pinok1”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx_builtins.c: Goto (macro-dialout-trunk,s,39)
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:39] NoOp(“SIP/212-00000033”, “OK”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:40] Set(“SIP/212-00000033”, “OUTNUM=02220660173”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:41] Set(“SIP/212-00000033”, “DEVICENUM=212”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:42] Set(“SIP/212-00000033”, “CIDNAME=”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:43] Set(“SIP/212-00000033”, “CIDNUM=”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:44] ExecIf(“SIP/212-00000033”, “1?Set(CIDNUM=212)”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:45] Set(“SIP/212-00000033”, “CDR(accountcode)=212”) in new stack
[May 22 07:37:12] WARNING[1439] func_cdr.c: Using the CDR function to set ‘accountcode’ is deprecated. Please use the CHANNEL function instead.
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:46] GotoIf(“SIP/212-00000033”, “0?ACCOUNTCODECFOK”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:47] ExecIf(“SIP/212-00000033”, “0?Set(CDR(accountcode)=212)”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:48] Goto(“SIP/212-00000033”, “ACCOUNTCODECFNOTOK”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx_builtins.c: Goto (macro-dialout-trunk,s,54)
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:54] Set(“SIP/212-00000033”, “custom=SIP/telkom2035075”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:55] GotoIf(“SIP/212-00000033”, “1?gocall”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx_builtins.c: Goto (macro-dialout-trunk,s,57)
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:57] Macro(“SIP/212-00000033”, “dialout-trunk-predial-hook,”) in new stack
[May 22 07:37:12] WARNING[3128][C-0000001f] app_macro.c: Context ‘macro-dialout-trunk-predial-hook’ for macro ‘dialout-trunk-predial-hook’ lacks ‘s’ extension, priority 1
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:58] GotoIf(“SIP/212-00000033”, “0?bypass,1”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:59] GotoIf(“SIP/212-00000033”, “0?customtrunk”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:60] Dial(“SIP/212-00000033”, “SIP/telkom2035075/02220660173,300,TW”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] netsock2.c: Using SIP RTP TOS bits 184
[May 22 07:37:12] VERBOSE[3128][C-0000001f] netsock2.c: Using SIP RTP CoS mark 5
[May 22 07:37:12] VERBOSE[3128][C-0000001f] app_dial.c: Called SIP/telkom2035075/02220660173
[May 22 07:37:12] VERBOSE[3128][C-0000001f] app_dial.c: Everyone is busy/congested at this time (1:0/0/1)
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-dialout-trunk:61] Goto(“SIP/212-00000033”, “s-CHANUNAVAIL,1”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx_builtins.c: Goto (macro-dialout-trunk,s-CHANUNAVAIL,1)
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s-CHANUNAVAIL@macro-dialout-trunk:1] GotoIf(“SIP/212-00000033”, “1?noreport”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx_builtins.c: Goto (macro-dialout-trunk,s-CHANUNAVAIL,3)
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s-CHANUNAVAIL@macro-dialout-trunk:3] NoOp(“SIP/212-00000033”, “TRUNK Dial failed due to CHANUNAVAIL - failing through to other trunks”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [902220660173@from-internal:5] Macro(“SIP/212-00000033”, “outisbusy,”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-outisbusy:1] Playback(“SIP/212-00000033”, “all-circuits-busy-now,noanswer”) in new stack
[May 22 07:37:12] VERBOSE[3128][C-0000001f] file.c: <SIP/212-00000033> Playing ‘all-circuits-busy-now.slin’ (language ‘en’)
[May 22 07:37:14] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-outisbusy:2] Playback(“SIP/212-00000033”, “pls-try-call-later,noanswer”) in new stack
[May 22 07:37:14] WARNING[3128][C-0000001f] file.c: File pls-try-call-later does not exist in any format
[May 22 07:37:14] WARNING[3128][C-0000001f] file.c: Unable to open pls-try-call-later (format (alaw)): No such file or directory
[May 22 07:37:14] WARNING[3128][C-0000001f] app_playback.c: Playback failed on SIP/212-00000033 for pls-try-call-later,noanswer
[May 22 07:37:14] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-outisbusy:3] Macro(“SIP/212-00000033”, “hangupcall”) in new stack
[May 22 07:37:14] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-hangupcall:1] GotoIf(“SIP/212-00000033”, “1?skiprg”) in new stack
[May 22 07:37:14] VERBOSE[3128][C-0000001f] pbx_builtins.c: Goto (macro-hangupcall,s,4)
[May 22 07:37:14] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-hangupcall:4] GotoIf(“SIP/212-00000033”, “1?skipblkvm”) in new stack
[May 22 07:37:14] VERBOSE[3128][C-0000001f] pbx_builtins.c: Goto (macro-hangupcall,s,7)
[May 22 07:37:14] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-hangupcall:7] GotoIf(“SIP/212-00000033”, “1?theend”) in new stack
[May 22 07:37:14] VERBOSE[3128][C-0000001f] pbx_builtins.c: Goto (macro-hangupcall,s,9)
[May 22 07:37:14] VERBOSE[3128][C-0000001f] pbx.c: Executing [s@macro-hangupcall:9] Hangup(“SIP/212-00000033”, “”) in new stack
[May 22 07:37:14] VERBOSE[3128][C-0000001f] app_macro.c: Spawn extension (macro-hangupcall, s, 9) exited non-zero on ‘SIP/212-00000033’ in macro ‘hangupcall’
[May 22 07:37:14] VERBOSE[3128][C-0000001f] app_macro.c: Spawn extension (macro-outisbusy, s, 3) exited non-zero on ‘SIP/212-00000033’ in macro ‘outisbusy’
[May 22 07:37:14] VERBOSE[3128][C-0000001f] pbx.c: Spawn extension (from-internal, 902220660173, 5) exited non-zero on ‘SIP/212-00000033’
[May 22 07:37:14] VERBOSE[3128][C-0000001f] pbx.c: Executing [h@from-internal:1] Macro(“SIP/212-00000033”, “hangupcall”) in new stack
[May 22 07:37:14] VERBOSE[3128][C-0000001f] pbx.c: Spawn extension (from-internal, h, 1) exited non-zero on ‘SIP/212-00000033’
