root@raspbx:~# install-dongle
Installing GSM VoIP gateway with chan_dongle.
Please read the documentation at http://raspbx.org/dongle
Please enter the phone number of your SIM card
(defaults to +1234567890 if left blank):
Send incoming SMS to email address
(leave empty to disable SMS forwarding):
Forward incoming SMS to mobile phone number (via dongle0)
(leave empty to disable):
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following extra packages will be installed:
libjim0.75 usb-modeswitch-data
Suggested packages:
comgt wvdial
The following NEW packages will be installed:
asterisk13-chandongle libjim0.75 usb-modeswitch usb-modeswitch-data
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Need to get 259 kB of archives.
After this operation, 778 kB of additional disk space will be used.
Get:1 http://repo.raspbx.org/apt/debian/ jessie/main asterisk13-chandongle all 1.1-34 [67.4 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main libjim0.75 armhf 0.75-1 [98.3 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ jessie/main usb-modeswitch-data all 20150115-1 [41.5 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ jessie/main usb-modeswitch armhf 2.2.0+repack0-2 [51.4 kB]
Fetched 2,796 B in 0s (97.7 kB/s)
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/j/jimtcl/libjim0.75_0.75-1_armhf.deb Size mismatch
E: Failed to fetch http://repo.raspbx.org/apt/debian/pool/main/a/asterisk13-chandongle/asterisk13-chandongle_1.1-34_all.deb Size mismatch
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/u/usb-modeswitch-data/usb-modeswitch-data_20150115-1_all.deb Size mismatch
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/u/usb-modeswitch/usb-modeswitch_2.2.0+repack0-2_armhf.deb Size mismatch
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Error installing chan_dongle and usb-modeswitch
ada ide untuk menyelesaikan masalah ini? kalo bisa akan saya kasih kredit +
