[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [088213553573@from-internal:1] Macro(“SIP/100-0000013b”, “user-callerid,SKIPTTL,”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-user-callerid:1] NoOp(“SIP/100-0000013b”, “user-callerid: device 100”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-user-callerid:2] Set(“SIP/100-0000013b”, “AMPUSER=100”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-user-callerid:3] GotoIf(“SIP/100-0000013b”, “0?report”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-user-callerid:4] ExecIf(“SIP/100-0000013b”, “1?Set(REALCALLERIDNUM=100)”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-user-callerid:5] NoOp(“SIP/100-0000013b”, “REALCALLERIDNUM is 100”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-user-callerid:6] Set(“SIP/100-0000013b”, “AMPUSER=100”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-user-callerid:7] Set(“SIP/100-0000013b”, “AMPUSERCIDNAME=100”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-user-callerid:8] GotoIf(“SIP/100-0000013b”, “0?report”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-user-callerid:9] Set(“SIP/100-0000013b”, “AMPUSERCID=100”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-user-callerid:10] Set(“SIP/100-0000013b”, “CALLERID(all)=“100” <100>”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-user-callerid:11] Set(“SIP/100-0000013b”, “REALCALLERIDNUM=100”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-user-callerid:12] ExecIf(“SIP/100-0000013b”, “0?Set(CHANNEL(language)=)”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-user-callerid:13] NoOp(“SIP/100-0000013b”, “TTL: ARG1: SKIPTTL”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-user-callerid:14] GotoIf(“SIP/100-0000013b”, “1?continue”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx_builtins.c: Goto (macro-user-callerid,s,23)
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-user-callerid:23] NoOp(“SIP/100-0000013b”, “Using CallerID “100” <100>”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [088213553573@from-internal:2] Set(“SIP/100-0000013b”, “_NODEST=”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [088213553573@from-internal:3] Macro(“SIP/100-0000013b”, “record-enable,100,OUT,”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-record-enable:1] GotoIf(“SIP/100-0000013b”, “0?2:4”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx_builtins.c: Goto (macro-record-enable,s,4)
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-record-enable:4] AGI(“SIP/100-0000013b”, “recordingcheck,20090101-075728,BrikerIPPBX-1230771448.621”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/recordingcheck
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] res_agi.c: recordingcheck,20090101-075728,BrikerIPPBX-1230771448.621: Outbound recording not enabled
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] res_agi.c: <SIP/100-0000013b>AGI Script recordingcheck completed, returning 0
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-record-enable:5] NoOp(“SIP/100-0000013b”, “No recording needed”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [088213553573@from-internal:4] Macro(“SIP/100-0000013b”, “dialout-trunk,5,088213553573,”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:1] Set(“SIP/100-0000013b”, “ENTEREDEXT=”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:2] NoOp(“SIP/100-0000013b”, “DEBUG: BT = CH = SIP/100-0000013b”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:3] Set(“SIP/100-0000013b”, “BT=”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:4] Set(“SIP/100-0000013b”, “BT=”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:5] NoOp(“SIP/100-0000013b”, “DEBUG: BT = CID = 100”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:6] GotoIf(“SIP/100-0000013b”, “1?authkeylock”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx_builtins.c: Goto (macro-dialout-trunk,s,9)
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:9] Set(“SIP/100-0000013b”, “KEYLOCK=”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:10] GotoIf(“SIP/100-0000013b”, “0?askpin:pinok”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx_builtins.c: Goto (macro-dialout-trunk,s,13)
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:13] NoOp(“SIP/100-0000013b”, “OK”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:14] Set(“SIP/100-0000013b”, “DIAL_TRUNK=5”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:15] Set(“SIP/100-0000013b”, “ZAP2DAHDI=SIP/indosat”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:16] Set(“SIP/100-0000013b”, “VAR1=SIP/”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:17] Set(“SIP/100-0000013b”, “VAR2=indosat”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:18] ExecIf(“SIP/100-0000013b”, “0?Set(OUT_5=DAHDI/indosat)”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:19] ExecIf(“SIP/100-0000013b”, “0?Set(OUT_5=DAHDI/indosat)”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:20] ExecIf(“SIP/100-0000013b”, “0?Set(OUT_5=DAHDI/indosat)”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:21] ExecIf(“SIP/100-0000013b”, “0?Authenticate()”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:22] GotoIf(“SIP/100-0000013b”, “0?disabletrunk,1”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:23] Set(“SIP/100-0000013b”, “DIAL_NUMBER=088213553573”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:24] Set(“SIP/100-0000013b”, “DIAL_TRUNK_OPTIONS=tTWr”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:25] Set(“SIP/100-0000013b”, “GROUP()=OUT_5”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:26] GotoIf(“SIP/100-0000013b”, “0?nomax”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:27] GotoIf(“SIP/100-0000013b”, “0?chanfull”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:28] GotoIf(“SIP/100-0000013b”, “0?skipoutcid”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:29] Set(“SIP/100-0000013b”, “DIAL_TRUNK_OPTIONS=TW”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:30] Macro(“SIP/100-0000013b”, “outbound-callerid,5”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-outbound-callerid:1] ExecIf(“SIP/100-0000013b”, “0?Set(CALLERPRES()=)”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-outbound-callerid:2] GotoIf(“SIP/100-0000013b”, “1?start”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx_builtins.c: Goto (macro-outbound-callerid,s,4)
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-outbound-callerid:4] NoOp(“SIP/100-0000013b”, “REALCALLERIDNUM is 100”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-outbound-callerid:5] GotoIf(“SIP/100-0000013b”, “1?normcid”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx_builtins.c: Goto (macro-outbound-callerid,s,10)
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-outbound-callerid:10] Set(“SIP/100-0000013b”, “USEROUTCID=+622130030777”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-outbound-callerid:11] Set(“SIP/100-0000013b”, “EMERGENCYCID=+622130030777”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-outbound-callerid:12] Set(“SIP/100-0000013b”, “TRUNKOUTCID=+622130030777”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-outbound-callerid:13] GotoIf(“SIP/100-0000013b”, “1?trunkcid”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx_builtins.c: Goto (macro-outbound-callerid,s,17)
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-outbound-callerid:17] GotoIf(“SIP/100-0000013b”, “0?usercid”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-outbound-callerid:18] Set(“SIP/100-0000013b”, “CALLERID(all)=+622130030777”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-outbound-callerid:19] GotoIf(“SIP/100-0000013b”, “0?report”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-outbound-callerid:20] Set(“SIP/100-0000013b”, “CALLERID(all)=+622130030777”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-outbound-callerid:21] GotoIf(“SIP/100-0000013b”, “1?report:hidecid”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx_builtins.c: Goto (macro-outbound-callerid,s,23)
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-outbound-callerid:23] NoOp(“SIP/100-0000013b”, “CallerID set to “” <+622130030777>”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:31] AGI(“SIP/100-0000013b”, “fixlocalprefix”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/fixlocalprefix
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] res_agi.c: <SIP/100-0000013b>AGI Script fixlocalprefix completed, returning 0
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:32] Set(“SIP/100-0000013b”, “OUTNUM=088213553573”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:33] Set(“SIP/100-0000013b”, “REALOUTNUM=088213553573”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:34] GotoIf(“SIP/100-0000013b”, “0?askpin1:pinok1”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx_builtins.c: Goto (macro-dialout-trunk,s,39)
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:39] NoOp(“SIP/100-0000013b”, “OK”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:40] Set(“SIP/100-0000013b”, “OUTNUM=088213553573”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:41] Set(“SIP/100-0000013b”, “DEVICENUM=100”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:42] Set(“SIP/100-0000013b”, “CIDNAME=”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:43] Set(“SIP/100-0000013b”, “CIDNUM=+622130030777”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:44] ExecIf(“SIP/100-0000013b”, “0?Set(CIDNUM=100)”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:45] Set(“SIP/100-0000013b”, “CDR(accountcode)=100”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:46] GotoIf(“SIP/100-0000013b”, “0?ACCOUNTCODECFOK”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:47] ExecIf(“SIP/100-0000013b”, “0?Set(CDR(accountcode)=+622130030777)”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:48] Goto(“SIP/100-0000013b”, “ACCOUNTCODECFNOTOK”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx_builtins.c: Goto (macro-dialout-trunk,s,54)
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:54] Set(“SIP/100-0000013b”, “custom=SIP/indosat”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:55] GotoIf(“SIP/100-0000013b”, “1?gocall”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx_builtins.c: Goto (macro-dialout-trunk,s,57)
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:57] Macro(“SIP/100-0000013b”, “dialout-trunk-predial-hook,”) in new stack
[Jan 1 07:57:28] WARNING[3596][C-000000a5] app_macro.c: Context ‘macro-dialout-trunk-predial-hook’ for macro ‘dialout-trunk-predial-hook’ lacks ‘s’ extension, priority 1
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:58] GotoIf(“SIP/100-0000013b”, “0?bypass,1”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:59] GotoIf(“SIP/100-0000013b”, “0?customtrunk”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:60] Dial(“SIP/100-0000013b”, “SIP/indosat/088213553573,300,TW”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] netsock2.c: Using SIP RTP TOS bits 184
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] netsock2.c: Using SIP RTP CoS mark 5
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] app_dial.c: Called SIP/indosat/088213553573
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] app_dial.c: Everyone is busy/congested at this time (1:0/0/1)
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-dialout-trunk:61] Goto(“SIP/100-0000013b”, “s-CHANUNAVAIL,1”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx_builtins.c: Goto (macro-dialout-trunk,s-CHANUNAVAIL,1)
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s-CHANUNAVAIL@macro-dialout-trunk:1] GotoIf(“SIP/100-0000013b”, “1?noreport”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx_builtins.c: Goto (macro-dialout-trunk,s-CHANUNAVAIL,3)
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s-CHANUNAVAIL@macro-dialout-trunk:3] NoOp(“SIP/100-0000013b”, “TRUNK Dial failed due to CHANUNAVAIL - failing through to other trunks”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [088213553573@from-internal:5] Macro(“SIP/100-0000013b”, “outisbusy,”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-outisbusy:1] Playback(“SIP/100-0000013b”, “all-circuits-busy-now,noanswer”) in new stack
[Jan 1 07:57:28] VERBOSE[3596][C-000000a5] file.c: <SIP/100-0000013b> Playing ‘all-circuits-busy-now.slin’ (language ‘en’)
[Jan 1 07:57:30] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-outisbusy:2] Playback(“SIP/100-0000013b”, “pls-try-call-later,noanswer”) in new stack
[Jan 1 07:57:30] WARNING[3596][C-000000a5] file.c: File pls-try-call-later does not exist in any format
[Jan 1 07:57:30] WARNING[3596][C-000000a5] file.c: Unable to open pls-try-call-later (format (alaw)): No such file or directory
[Jan 1 07:57:30] WARNING[3596][C-000000a5] app_playback.c: Playback failed on SIP/100-0000013b for pls-try-call-later,noanswer
[Jan 1 07:57:30] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-outisbusy:3] Macro(“SIP/100-0000013b”, “hangupcall”) in new stack
[Jan 1 07:57:30] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-hangupcall:1] GotoIf(“SIP/100-0000013b”, “1?skiprg”) in new stack
[Jan 1 07:57:30] VERBOSE[3596][C-000000a5] pbx_builtins.c: Goto (macro-hangupcall,s,4)
[Jan 1 07:57:30] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-hangupcall:4] GotoIf(“SIP/100-0000013b”, “1?skipblkvm”) in new stack
[Jan 1 07:57:30] VERBOSE[3596][C-000000a5] pbx_builtins.c: Goto (macro-hangupcall,s,7)
[Jan 1 07:57:30] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-hangupcall:7] GotoIf(“SIP/100-0000013b”, “1?theend”) in new stack
[Jan 1 07:57:30] VERBOSE[3596][C-000000a5] pbx_builtins.c: Goto (macro-hangupcall,s,9)
[Jan 1 07:57:30] VERBOSE[3596][C-000000a5] pbx.c: Executing [s@macro-hangupcall:9] Hangup(“SIP/100-0000013b”, “”) in new stack
[Jan 1 07:57:30] VERBOSE[3596][C-000000a5] app_macro.c: Spawn extension (macro-hangupcall, s, 9) exited non-zero on ‘SIP/100-0000013b’ in macro ‘hangupcall’
[Jan 1 07:57:30] VERBOSE[3596][C-000000a5] app_macro.c: Spawn extension (macro-outisbusy, s, 3) exited non-zero on ‘SIP/100-0000013b’ in macro ‘outisbusy’
[Jan 1 07:57:30] VERBOSE[3596][C-000000a5] pbx.c: Spawn extension (from-internal, 088213553573, 5) exited non-zero on ‘SIP/100-0000013b’
[Jan 1 07:57:30] VERBOSE[3596][C-000000a5] pbx.c: Executing [h@from-internal:1] Macro(“SIP/100-0000013b”, “hangupcall”) in new stack
[Jan 1 07:57:30] VERBOSE[3596][C-000000a5] pbx.c: Spawn extension (from-internal, h, 1) exited non-zero on ‘SIP/100-0000013b’
