mas @asoka : pakah ada perubahan untuk ip address DSS? Saya kok ndak bisa ping sama sekali ke ip address ini.
Berikut capture traceroute:
Tidak ada pak, saya coba trace bisa.
traceroute to dss.teleponrakyat.id (202.153.128.61), 30 hops max, 60 byte packets
1 192.168.12.1 (192.168.12.1) 5.249 ms 8.377 ms 10.542 ms
2 unknown.telstraglobal.net (202.47.201.193) 18.431 ms 19.145 ms 19.150 ms
3 21479.jkt04.cu.telstraglobal.net (202.47.195.49) 19.150 ms 19.149 ms 19.150 ms
4 202.47.192.197 (202.47.192.197) 19.148 ms 19.147 ms 19.146 ms
5 i-0-1-0-3.ijcb-core02.bx.telstraglobal.net (202.84.141.78) 19.144 ms 19.147 ms 19.146 ms
6 i-0-4-1-7.istt-core02.bx.telstraglobal.net (202.84.141.77) 30.038 ms 22.099 ms 22.747 ms
7 i-0-0-0-6.istt04.bi.telstraglobal.net (202.84.225.254) 22.522 ms i-0-0-0-2.istt04.bi.telstraglobal.net (202.84.225.221) 26.156 ms i-0-0-0-6.istt04.bi.telstraglobal.net (202.84.225.254) 22.692 ms
8 9505.sgw.equinix.com (27.111.228.63) 90.676 ms 90.669 ms 90.659 ms
9 78-61-41-175.TWGATE-IP.twgate.net (175.41.61.78) 62.085 ms 64.114 ms 64.503 ms
10 114.4.19.78 (114.4.19.78) 77.330 ms 78.902 ms 78.897 ms
11 114.4.98.134 (114.4.98.134) 29.805 ms 18.566 ms 28.812 ms
12 202.153.128.61 (202.153.128.61) 28.379 ms 19.092 ms 27.116 ms
Hmm… aneh… saya sudah coba dari beberapa network down. Salah satunya
voip.magetankab.go.id (0.0.0.0) Mon Oct 3 09:54:16 2016
Keys: Help Display mode Restart statistics Order of fields quit
Packets Pings
Host Loss% Snt Last Avg Best Wrst StDev
- host-103-205-82-21.magetankab.go.id 0.0% 9 0.2 0.1 0.1 0.2 0.0
- host-103-205-82-237.magetankab.go.id 0.0% 9 0.2 0.2 0.2 0.4 0.0
- host-103-205-82-233.magetankab.go.id 0.0% 9 19.5 19.4 19.3 19.5 0.1
- host-103-205-82-254.magetankab.go.id 0.0% 9 19.8 19.7 19.4 20.4 0.3
- 114.4.28.5 0.0% 9 20.3 23.7 20.3 30.0 3.9
Sudah dicoba trace dari network lain mas @asoka ?
Dari fastnet nih :
traceroute to sip.teleponrakyat.id (202.153.128.61), 30 hops max, 60 byte packets
1 172.16.16.254 (172.16.16.254) 0.322 ms 0.424 ms 0.524 ms
2 10.36.96.1 (10.36.96.1) 11.836 ms 11.839 ms 11.948 ms
3 be8-pe04-cg03.fast.net.id (202.73.96.26) 18.776 ms 18.788 ms 18.647 ms
4 be8-cg03-pe04.fast.net.id (202.73.96.25) 19.855 ms 19.835 ms 19.261 ms
5 lynx-static-116-68-231-17.lynx.net.id (116.68.231.17) 32.902 ms 32.900 ms 32.947 ms
6 lynx-static-116-68-231-178.lynx.net.id (116.68.231.178) 35.861 ms 30.284 ms 28.455 ms
7 9505.sgw.equinix.com (27.111.228.63) 26.184 ms 26.404 ms 26.378 ms
8 78-61-41-175.TWGATE-IP.twgate.net (175.41.61.78) 26.509 ms 35.742 ms 35.721 ms
9 114.4.19.78 (114.4.19.78) 51.439 ms 47.717 ms 47.717 ms
10 114.4.98.134 (114.4.98.134) 43.669 ms 34.568 ms 31.432 ms
11 202.153.128.61 (202.153.128.61) 29.966 ms 29.946 ms 30.185 ms
[root@mx ~]# traceroute 202.153.128.61
traceroute to 202.153.128.61 (202.153.128.61), 30 hops max, 40 byte packets
1 192.168.5.1 (192.168.5.1) 0.706 ms 0.675 ms 0.673 ms
2 1.3.144.122.maxindo.net (122.144.3.1) 0.668 ms 0.671 ms 0.665 ms
3 29.32.103.175.maxindo.net (175.103.32.29) 1.236 ms 1.225 ms 1.476 ms
4 (103.244.51.118) 1.471 ms 1.477 ms 1.469 ms
5 IP-117-1.MCS.internet.exchange (119.110.117.1) 1.866 ms 1.456 ms 1.850 ms
6 9505.sgw.equinix.com (27.111.228.63) 15.833 ms 16.560 ms 15.777 ms
7 78-61-41-175.TWGATE-IP.twgate.net (175.41.61.78) 16.308 ms 15.965 ms 16.272 ms
8 114.4.19.78 (114.4.19.78) 28.844 ms 28.823 ms 30.771 ms
9 114.4.98.134 (114.4.98.134) 18.447 ms 18.433 ms 18.119 ms
10 202.153.128.61 (202.153.128.61) 15.207 ms 15.203 ms 15.162 ms
dari pakistan
1 FE-3-0-100M-CORE.nexlinx.net.pk (202.59.80.2) 0.392 ms 0.175 ms 0.171 ms
2 10.10.80.11 (10.10.80.11) 0.827 ms 0.467 ms 0.814 ms
3 tw21-static21.tw1.com (117.20.21.21) 0.778 ms 0.569 ms 0.745 ms
4 110.93.252.204 (110.93.252.204) 16.481 ms 110.93.252.160 (110.93.252.160) 20.689 ms 110.93.252.33 (110.93.252.33) 22.299 ms
5 tw255-static139.tw1.com (110.93.255.139) 16.925 ms 110.93.253.208 (110.93.253.208) 21.084 ms tw255-static139.tw1.com (110.93.255.139) 21.202 ms
6 110.93.253.146 (110.93.253.146) 158.435 ms tw255-static175.tw1.com (110.93.255.175) 143.826 ms 110.93.253.146 (110.93.253.146) 155.771 ms
7 xe9-0-6.franco71.fra.seabone.net (195.22.214.234) 187.484 ms 183.906 ms 188.061 ms
8 et1-1-0.franco32.fra.seabone.net (195.22.214.167) 184.379 ms et8-3-0.franco32.fra.seabone.net (195.22.214.219) 189.984 ms 193.393 ms
9 63-222-0-9.static.pccwglobal.net (63.222.0.9) 157.913 ms 152.775 ms 157.264 ms
10 HundredGE0-6-0-0.br02.hkg15.pccwbtn.net (63.223.15.190) 392.482 ms TenGE0-4-0-22.br02.hkg15.pccwbtn.net (63.223.17.38) 438.622 ms 433.717 ms
11 HundredGE0-6-0-0.br02.hkg15.pccwbtn.net (63.223.15.190) 392.332 ms indosat.ge13-26.br01.hkg04.pccwbtn.net (63.218.61.170) 439.285 ms HundredGE0-6-0-0.br02.hkg15.pccwbtn.net (63.223.15.190) 393.472 ms
12 indosat.ge13-26.br01.hkg04.pccwbtn.net (63.218.61.170) 390.890 ms 390.756 ms 114.4.19.78 (114.4.19.78) 479.627 ms
13 114.4.19.78 (114.4.19.78) 431.412 ms 438.763 ms 439.072 ms
14 202.153.128.61 (202.153.128.61) 489.104 ms 114.4.98.134 (114.4.98.134) 477.386 ms 471.957 ms
dari polandia
traceroute to 202.153.128.61 (202.153.128.61), 30 hops max, 60 byte packets
2 217.153.235.185 (217.153.235.185) 0.902 ms 0.978 ms 1.020 ms
3 193.85.195.170 (193.85.195.170) 15.045 ms 15.486 ms 15.509 ms
4 80.249.210.222 (80.249.210.222) 318.778 ms 318.780 ms 318.762 ms
5 114.4.19.78 (114.4.19.78) 336.246 ms 333.942 ms 330.248 ms
6 114.4.98.134 (114.4.98.134) 308.230 ms 308.655 ms 310.351 ms
7 202.153.128.61 (202.153.128.61) 322.606 ms 323.120 ms 326.070 ms
coba mas test deh traceroutenya dari linux
wah … ini kayaknya FMCOPD…
Faktor Muka Coba Operasi Plastik Dulu.
Oke om om sekalian… coba aku cari ini problemku di mana.
