Briker 2.1.1: DB Error: connect failed -> no such database
Selamat pagi !
I’ve installed briker Merapi successfully as Vmware guest.
When connecting to http://<briker_host:443>, I get:
When trying to start mysql as root on command line, here it fails like this:
root@ippbx:/var/log/upstart# start mysql
start: Job failed to start
I succeded starting mysql using:
su - mysql -s /bin/sh -c "/usr/bin/mysqld_safe "
But reload web browser still gives “DB Error: no such database”
How should I initialise the briker database ?
Is this problem solved @berryamin ? I just listened because the problem I was experiencing
pak @asoka mungkin bisa bantu?
