[ASK] Linksys SPA400 Briker - Tidak Bisa Call Dari Ext PABX ke Softphone
Hallo semua, salam kenal sebelumnya.
Saya sedang membangun VOIP di kantor, dimana Topologinya adalah :
PABX Panasonic - ext301, ext302
Linksys Spa400
Briker
SoftPhone<3001> , SoftPhone<3002>
Ket : Ext 301 dan 302 Terhubung ke port FXO di linksys spa400
Kondisi saat ini : Dari SoftPhone<3001> , SoftPhone<3002> menelpon ke Ext PABX berjalan dengan baik.
Namun ketika dicoba menelepon dari Ext PABX conth Ext 101 menelpon ke Ext301 tidak diteruskan ke SoftPhone<3001> padahal sudah disetting Inbound nya.
Setting Trunk SPA400
PEER Detail
allow=ULAW&ALAW
call-limit=50
canreinvite=no
host=192.168.8.53
insecure=very
secret=
username=9000
Inbound Route Briker
DID kosong
Set Destination ke SoftPhone 3001
Mohon Pencerahanya om om semua, apa ada yang terlewat untuk setting inbound route nya, terima kasih
ada baiknya jika disertakan log hasil dari test call tersebut. Biasanya ada di /var/log/asterisk/full atau /var/log/asterisk/messages .
Hallo Om,
saya coba dial dari extPabx ke softphone ada suara " The Number You’ve Dial Is Not In services "
saya tail -f /var/log/asterisk/messages keluar begini om
[Jan 8 19:54:14] NOTICE[1416] chan_sip.c: Registration from ‘941 sip:941@192.168.8.52:5060’ failed for ‘192.168.8.1:36560’ - Wrong password
[Jan 8 19:54:22] NOTICE[1416] chan_sip.c: Registration from ‘951 sip:951@192.168.8.52:5060’ failed for ‘192.168.8.1:34486’ - Wrong password
[Jan 8 19:54:29] NOTICE[1416] chan_sip.c: Registration from ‘961 sip:961@192.168.8.52:5060’ failed for ‘192.168.8.1:5066’ - Wrong password
[Jan 8 19:54:37] NOTICE[1416] chan_sip.c: Registration from ‘971 sip:971@192.168.8.52:5060’ failed for ‘192.168.8.1:50616’ - Wrong password
[Jan 8 19:54:44] NOTICE[1416] chan_sip.c: Registration from ‘981 sip:981@192.168.8.52:5060’ failed for ‘192.168.8.1:5092’ - Wrong password
[Jan 8 19:54:51] NOTICE[1416] chan_sip.c: Registration from ‘466 sip:466@192.168.8.52:5060’ failed for ‘192.168.8.1:59064’ - Wrong password
[Jan 8 19:54:58] NOTICE[1416] chan_sip.c: Registration from ‘1115 sip:1115@192.168.8.52:5060’ failed for ‘192.168.8.1:5072’ - Wrong password
[Jan 8 19:55:05] NOTICE[1416] chan_sip.c: Registration from ‘1110 sip:1110@192.168.8.52:5060’ failed for ‘192.168.8.1:43711’ - Wrong password
[Jan 8 19:55:14] NOTICE[1416] chan_sip.c: Registration from ‘1212 sip:1212@192.168.8.52:5060’ failed for ‘192.168.8.1:1105’ - Wrong password
[Jan 8 19:55:20] NOTICE[1416] chan_sip.c: Registration from ‘1313 sip:1313@192.168.8.52:5060’ failed for ‘192.168.8.1:1144’ - Wrong password
[Jan 8 19:55:28] NOTICE[1416] chan_sip.c: Registration from ‘1414 sip:1414@192.168.8.52:5060’ failed for ‘192.168.8.1:40321’ - Wrong password
[Jan 8 19:55:34] NOTICE[1416] chan_sip.c: Registration from ‘1515 sip:1515@192.168.8.52:5060’ failed for ‘192.168.8.1:5066’ - Wrong password
[Jan 8 19:55:41] NOTICE[1416] chan_sip.c: Registration from ‘1616 sip:1616@192.168.8.52:5060’ failed for ‘192.168.8.1:39700’ - Wrong password
[Jan 8 19:55:49] NOTICE[1416] chan_sip.c: Registration from ‘1717 sip:1717@192.168.8.52:5060’ failed for ‘192.168.8.1:1116’ - Wrong password
[Jan 8 19:55:56] NOTICE[1416] chan_sip.c: Registration from ‘1818 sip:1818@192.168.8.52:5060’ failed for ‘192.168.8.1:1114’ - Wrong password
[Jan 8 19:56:04] NOTICE[1416] chan_sip.c: Registration from ‘1919 sip:1919@192.168.8.52:5060’ failed for ‘192.168.8.1:59576’ - Wrong password
[Jan 8 19:56:11] NOTICE[1416] chan_sip.c: Registration from ‘2121 sip:2121@192.168.8.52:5060’ failed for ‘192.168.8.1:1112’ - Wrong password
[Jan 8 19:56:18] NOTICE[1416] chan_sip.c: Registration from ‘2323 sip:2323@192.168.8.52:5060’ failed for ‘192.168.8.1:5091’ - Wrong password
kalau pake CLI nya Asterisk -rvvvvvv keluar begini om telpon dari ExtPabx ke Softphone
> <--- SIP read from UDP:192.168.8.53:5060 --->
NOTIFY sip:9000@:0 SIP/2.0
Via: SIP/2.0/UDP 192.168.8.53:5060;branch=z9hG4bK38f947cb
From: "SPA400" <sip:SPA400@192.168.8.53>;tag=as327b23c6
To: <sip:9000@:0>
Contact: <sip:SPA400@192.168.8.53>
Call-ID: 474d9ecd0717461509f5f50b738fdb63@192.168.8.53
CSeq: 619 NOTIFY
User-Agent: LINKSYS/SPA400
Event: fxo-port-state;partial;1=inuse,v=28
Content-Length: 0
--- (10 headers 1 lines) ---
Sending to 192.168.8.53:5060 (no NAT)
<--- Transmitting (no NAT) to 192.168.8.53:5060 --->
SIP/2.0 489 Bad event
Via: SIP/2.0/UDP 192.168.8.53:5060;branch=z9hG4bK38f947cb;received=192.168.8.53
To: <sip:9000@:0>;tag=as190eb612
CSeq: 619 NOTIFY
Server: BrikerIPPBX
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
Supported: replaces, timer
Content-Length: 0
Scheduling destruction of SIP dialog '474d9ecd0717461509f5f50b738fdb63@192.168.8.53' in 32000 ms (Method: NOTIFY)
Via: SIP/2.0/UDP 192.168.8.53:5060;branch=z9hG4bK7d43467f
To: <sip:9000@:0>
Call-ID: 56d5a637012ecc3f3a4ce025710d1a07@192.168.8.53
CSeq: 620 NOTIFY
Event: fxo-port-state;partial;1=ring,v=28
Content-Length: 0
Via: SIP/2.0/UDP 192.168.8.53:5060;branch=z9hG4bK7d43467f;received=192.168.8.53
To: <sip:9000@:0>;tag=as1a275ec7
CSeq: 620 NOTIFY
Server: BrikerIPPBX
Content-Length: 0
Scheduling destruction of SIP dialog '56d5a637012ecc3f3a4ce025710d1a07@192.168.8.53' in 32000 ms (Method: NOTIFY)
    -- Registered SIP '3001' at 192.168.8.220:5060
    -- Registered SIP '3001' at 192.168.8.1:1149
  == Manager 'admin' logged on from 127.0.0.1
  == Manager 'admin' logged off from 127.0.0.1
INVITE sip:9000@192.168.8.52 SIP/2.0
From: - 3311<sip:anonymous@localhost>;tag=3508a8c0-13c4-3d7ec84e-ddc9b1f-78bccb7
To: <sip:3311@192.168.8.53>
Call-ID: 10195414-3508a8c0-13c4-3d7ec84e-ddc9b1f-710ca351@localhost
CSeq: 1 INVITE
Via: SIP/2.0/UDP 192.168.8.53:5060;branch=z9hG4bK-3d7ec84e-ddc9b1f-1b701c24
Max-Forwards: 70
Supported: replaces,timer,100rel
Contact: <sip:3311@192.168.8.53:5060;transport=UDP>
Content-Type: application/SDP
Content-Length: 288
v=0
o=anonymous 8884 6672 IN IP4 192.168.8.53
s=SIP Call
c=IN IP4 192.168.8.53
t=0 0
m=audio 10002 RTP/AVP 8 101 0 18
a=ptime:30
a=fmtp:101 0-15
a=fmtp:18 annexb=no
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=sendrecv
--- (11 headers 14 lines) ---
Using INVITE request as basis request - 10195414-3508a8c0-13c4-3d7ec84e-ddc9b1f-710ca351@localhost
Found peer 'spa400' for 'anonymous' from 192.168.8.53:5060
  == Using SIP VIDEO TOS bits 136
  == Using SIP VIDEO CoS mark 6
  == Using SIP RTP TOS bits 184
  == Using SIP RTP CoS mark 5
Found RTP audio format 8
Found RTP audio format 101
Found RTP audio format 0
Found RTP audio format 18
Found audio description format PCMA for ID 8
Found audio description format telephone-event for ID 101
Found audio description format PCMU for ID 0
Found audio description format G729 for ID 18
Capabilities: us - (alaw|ulaw|vp8|h264|h263p|h263), peer - audio=(ulaw|alaw|g729)/video=(nothing)/text=(nothing), combined - (alaw|ulaw)
Non-codec capabilities (dtmf): us - 0x1 (telephone-event|), peer - 0x1 (telephone-event|), combined - 0x1 (telephone-event|)
Peer audio RTP is at port 192.168.8.53:10002
Peer doesn't provide video
Peer doesn't provide T.140
Looking for 9000 in from-sip-external (domain 192.168.8.52)
sip_route_dump: route/path hop: <sip:3311@192.168.8.53:5060;transport=UDP>
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.8.53:5060;branch=z9hG4bK-3d7ec84e-ddc9b1f-1b701c24;received=192.168.8.53
CSeq: 1 INVITE
Server: BrikerIPPBX
Session-Expires: 1800;refresher=uas
Contact: <sip:9000@192.168.8.52:5060>
Content-Length: 0
    -- Executing [9000@from-sip-external:1] NoOp("SIP/spa400-00002984", "Received incoming SIP connection from unknown peer to 9000") in new stack
    -- Executing [9000@from-sip-external:2] Set("SIP/spa400-00002984", "DID=9000") in new stack
    -- Executing [9000@from-sip-external:3] Goto("SIP/spa400-00002984", "s,1") in new stack
    -- Goto (from-sip-external,s,1)
    -- Executing [s@from-sip-external:1] GotoIf("SIP/spa400-00002984", "0?from-trunk,9000,1") in new stack
    -- Executing [s@from-sip-external:2] Set("SIP/spa400-00002984", "TIMEOUT(absolute)=15") in new stack
    -- Channel will hangup at 2018-01-08 19:57:56.889 WIB.
    -- Executing [s@from-sip-external:3] Answer("SIP/spa400-00002984", "") in new stack
Audio is at 12948
Adding codec alaw to SDP
Adding codec ulaw to SDP
Adding non-codec 0x1 (telephone-event) to SDP
<--- Reliably Transmitting (no NAT) to 192.168.8.53:5060 --->
SIP/2.0 200 OK
To: <sip:3311@192.168.8.53>;tag=as2fb81554
CSeq: 1 INVITE
Server: BrikerIPPBX
Content-Type: application/sdp
Require: timer
Content-Length: 263
v=0
o=root 1554670896 1554670896 IN IP4 192.168.8.52
s=Asterisk PBX 13.9.1
c=IN IP4 192.168.8.52
t=0 0
m=audio 12948 RTP/AVP 8 0 101
a=fmtp:101 0-16
a=maxptime:150
a=sendrecv
ACK sip:9000@192.168.8.52:5060 SIP/2.0
From: <sip:anonymous@localhost>;tag=3508a8c0-13c4-3d7ec84e-ddc9b1f-78bccb7
CSeq: 1 ACK
Via: SIP/2.0/UDP 192.168.8.53:5060;branch=z9hG4bK-3d7ec84e-ddc9b97-3f27238d
Max-Forwards: 70
Content-Length: 0
--- (9 headers 0 lines) ---
Via: SIP/2.0/UDP 192.168.8.53:5060;branch=z9hG4bK3013a7f3
To: <sip:9000@:0>
Call-ID: 283faa4d68233d434ac8b3f12d6c8d80@192.168.8.53
CSeq: 621 NOTIFY
Event: fxo-port-state;partial;1=off,v=28
Content-Length: 0
Via: SIP/2.0/UDP 192.168.8.53:5060;branch=z9hG4bK3013a7f3;received=192.168.8.53
To: <sip:9000@:0>;tag=as5a768234
CSeq: 621 NOTIFY
Server: BrikerIPPBX
Content-Length: 0
Scheduling destruction of SIP dialog '283faa4d68233d434ac8b3f12d6c8d80@192.168.8.53' in 32000 ms (Method: NOTIFY)
       > 0x7f9109523840 -- Probation passed - setting RTP source address to 192.168.8.53:10002
    -- Executing [s@from-sip-external:4] Wait("SIP/spa400-00002984", "2") in new stack
Via: SIP/2.0/UDP 192.168.8.53:5060;branch=z9hG4bK06af1767
To: <sip:9000@:0>
Call-ID: 5a0c8ee61644e7a84583609e575cb903@192.168.8.53
CSeq: 622 NOTIFY
Event: fxo-port-state;partial;1=off,v=7
Content-Length: 0
Via: SIP/2.0/UDP 192.168.8.53:5060;branch=z9hG4bK06af1767;received=192.168.8.53
To: <sip:9000@:0>;tag=as1065636e
CSeq: 622 NOTIFY
Server: BrikerIPPBX
Content-Length: 0
Scheduling destruction of SIP dialog '5a0c8ee61644e7a84583609e575cb903@192.168.8.53' in 32000 ms (Method: NOTIFY)
    -- Executing [s@from-sip-external:5] Playback("SIP/spa400-00002984", "ss-noservice") in new stack
    -- <SIP/spa400-00002984> Playing 'ss-noservice.slin' (language 'en')
    -- Executing [s@from-sip-external:6] PlayTones("SIP/spa400-00002984", "congestion") in new stack
    -- Executing [s@from-sip-external:7] Congestion("SIP/spa400-00002984", "5") in new stack
  == Spawn extension (from-sip-external, s, 7) exited non-zero on 'SIP/spa400-00002984'
    -- Executing [h@from-sip-external:1] NoOp("SIP/spa400-00002984", "Hangup") in new stack
    -- Executing [h@from-sip-external:2] Set("SIP/spa400-00002984", "DID=s") in new stack
    -- Executing [h@from-sip-external:3] Goto("SIP/spa400-00002984", "s,1") in new stack
    -- Executing [s@from-sip-external:1] GotoIf("SIP/spa400-00002984", "0?from-trunk,s,1") in new stack
    -- Channel will hangup at 2018-01-08 19:58:08.992 WIB.
  == Spawn extension (from-sip-external, s, 3) exited non-zero on 'SIP/spa400-00002984'
Scheduling destruction of SIP dialog '10195414-3508a8c0-13c4-3d7ec84e-ddc9b1f-710ca351@localhost' in 32000 ms (Method: ACK)
set_destination: Parsing <sip:3311@192.168.8.53:5060;transport=UDP> for address/port to send to
set_destination: set destination to 192.168.8.53:5060
Reliably Transmitting (no NAT) to 192.168.8.53:5060:
BYE sip:3311@192.168.8.53:5060;transport=UDP SIP/2.0
Via: SIP/2.0/UDP 192.168.8.52:5060;branch=z9hG4bK6eeaf0c8
Max-Forwards: 70
To: - 3311<sip:anonymous@localhost>;tag=3508a8c0-13c4-3d7ec84e-ddc9b1f-78bccb7
CSeq: 102 BYE
User-Agent: BrikerIPPBX
X-Asterisk-HangupCause: Unknown
X-Asterisk-HangupCauseCode: 0
Content-Length: 0
SIP/2.0 200 OK
To: <sip:anonymous@localhost>;tag=3508a8c0-13c4-3d7ec84e-ddc9b1f-78bccb7
CSeq: 102 BYE
Content-Length: 0
--- (8 headers 0 lines) ---
SIP Response message for INCOMING dialog BYE arrived
Really destroying SIP dialog '10195414-3508a8c0-13c4-3d7ec84e-ddc9b1f-710ca351@localhost' Method: ACK
Via: SIP/2.0/UDP 192.168.8.53:5060;branch=z9hG4bK3d0ece53
To: <sip:9000@:0>
Call-ID: 2f0c2f412a5099394704c35e229c0aa5@192.168.8.53
CSeq: 623 NOTIFY
Event: fxo-port-state;partial;1=on,v=7
Content-Length: 0
Via: SIP/2.0/UDP 192.168.8.53:5060;branch=z9hG4bK3d0ece53;received=192.168.8.53
To: <sip:9000@:0>;tag=as399e2b5c
CSeq: 623 NOTIFY
Server: BrikerIPPBX
Content-Length: 0
Scheduling destruction of SIP dialog '2f0c2f412a5099394704c35e229c0aa5@192.168.8.53' in 32000 ms (Method: NOTIFY)
Via: SIP/2.0/UDP 192.168.8.53:5060;branch=z9hG4bK2793dfb8
To: <sip:9000@:0>
Call-ID: 1dda699623cad6e461e0bfdd0ee7839d@192.168.8.53
CSeq: 624 NOTIFY
Event: fxo-port-state;partial;1=on,v=28
Content-Length: 0
Via: SIP/2.0/UDP 192.168.8.53:5060;branch=z9hG4bK2793dfb8;received=192.168.8.53
To: <sip:9000@:0>;tag=as76836b77
CSeq: 624 NOTIFY
Server: BrikerIPPBX
Content-Length: 0
sudah done mas @godril untuk incoming dan outgoing
saya ubah trunk nya menjadi
host=192.168.8.53
username=9000
nat=no
directmedia=no
allow=alaw&ulaw
transport=udp
yang jadi maalah sekarang gimana cara setting incoming untuk masing2 port fxo linksys diarahkan ke softphone yang berbeda beda, karena saya test call dari extpabx ke softphone yang keluar namanya anonymous dan no - 11301
fyi : port id linksys spa400 : port 1 = 11301, port 2 = 11302
