[2018-04-03 09:21:49] VERBOSE[1994][C-00000078] netsock2.c: Using SIP RTP TOS bits 184
[2018-04-03 09:21:49] VERBOSE[1994][C-00000078] netsock2.c: Using SIP RTP CoS mark 5
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [69@from-internal:1] GotoIf(“SIP/688-000000e4”, “1?ext-local,69,1:followme-check,69,1”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx_builtins.c: Goto (ext-local,69,1)
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [69@ext-local:1] Set(“SIP/688-000000e4”, “__RINGTIMER=15”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [69@ext-local:2] Macro(“SIP/688-000000e4”, “exten-vm,novm,69,0,0,0”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-exten-vm:1] Macro(“SIP/688-000000e4”, “user-callerid,”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:1] Set(“SIP/688-000000e4”, “TOUCH_MONITOR=1522722109.228”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:2] Set(“SIP/688-000000e4”, “AMPUSER=688”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:3] GotoIf(“SIP/688-000000e4”, “0?report”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:4] ExecIf(“SIP/688-000000e4”, “1?Set(__REALCALLERIDNUM=688)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:5] Set(“SIP/688-000000e4”, “AMPUSER=688”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:6] GotoIf(“SIP/688-000000e4”, “0?limit”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:7] Set(“SIP/688-000000e4”, “AMPUSERCIDNAME=Yusuf R Hakim”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:8] GotoIf(“SIP/688-000000e4”, “0?report”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:9] Set(“SIP/688-000000e4”, “AMPUSERCID=688”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:10] Set(“SIP/688-000000e4”, “__DIAL_OPTIONS=Ttr”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:11] Set(“SIP/688-000000e4”, “CALLERID(all)=“Yusuf R Hakim” <688>”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:12] GotoIf(“SIP/688-000000e4”, “0?limit”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:13] ExecIf(“SIP/688-000000e4”, “0?Set(GROUP(concurrency_limit)=688)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:14] ExecIf(“SIP/688-000000e4”, “0?Set(CHANNEL(language)=)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:15] GotoIf(“SIP/688-000000e4”, “0?continue”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:16] ExecIf(“SIP/688-000000e4”, “1?Set(__CALLEE_ACCOUNCODE=)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:17] Set(“SIP/688-000000e4”, “__TTL=6”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:18] GotoIf(“SIP/688-000000e4”, “1?continue”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx_builtins.c: Goto (macro-user-callerid,s,29)
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:29] Set(“SIP/688-000000e4”, “CALLERID(number)=688”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:30] Set(“SIP/688-000000e4”, “CALLERID(name)=Yusuf R Hakim”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:31] GotoIf(“SIP/688-000000e4”, “0?cnum”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:32] Set(“SIP/688-000000e4”, “CDR(cnam)=Yusuf R Hakim”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:33] Set(“SIP/688-000000e4”, “CDR(cnum)=688”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-user-callerid:34] Set(“SIP/688-000000e4”, “CHANNEL(language)=en”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-exten-vm:2] Set(“SIP/688-000000e4”, “RingGroupMethod=none”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-exten-vm:3] Set(“SIP/688-000000e4”, “__EXTTOCALL=69”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-exten-vm:4] Set(“SIP/688-000000e4”, “__PICKUPMARK=69”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-exten-vm:5] Set(“SIP/688-000000e4”, “RT=”) in new stack
[2018-04-03 09:21:49] ERROR[15945][C-00000078] res_pjsip_header_funcs.c: This function requires a PJSIP channel.
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-exten-vm:6] ExecIf(“SIP/688-000000e4”, “0?Macro(vm,novm,DIRECTDIAL,)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-exten-vm:7] ExecIf(“SIP/688-000000e4”, “0?MacroExit()”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-exten-vm:8] ExecIf(“SIP/688-000000e4”, “0?Gosub(ext-intercom,nointercom69,1())”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-exten-vm:9] ExecIf(“SIP/688-000000e4”, “0?MacroExit()”) in new stack
[2018-04-03 09:21:49] WARNING[15945][C-00000078] pbx_functions.c: Can’t find trailing parenthesis for function ‘DB(DEVICE/69/dial’?
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-exten-vm:10] ExecIf(“SIP/688-000000e4”, “0?ChanSpy(SIP/69,q)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-exten-vm:11] ExecIf(“SIP/688-000000e4”, “0?MacroExit()”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-exten-vm:12] Gosub(“SIP/688-000000e4”, “sub-record-check,s,1(exten,69,dontcare)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@sub-record-check:1] GotoIf(“SIP/688-000000e4”, “0?initialized”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@sub-record-check:2] Set(“SIP/688-000000e4”, “__REC_STATUS=INITIALIZED”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@sub-record-check:3] Set(“SIP/688-000000e4”, “NOW=1522722109”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@sub-record-check:4] Set(“SIP/688-000000e4”, “__DAY=03”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@sub-record-check:5] Set(“SIP/688-000000e4”, “__MONTH=04”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@sub-record-check:6] Set(“SIP/688-000000e4”, “__YEAR=2018”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@sub-record-check:7] Set(“SIP/688-000000e4”, “__TIMESTR=20180403-092149”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@sub-record-check:8] Set(“SIP/688-000000e4”, “__FROMEXTEN=688”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@sub-record-check:9] Set(“SIP/688-000000e4”, “__MON_FMT=wav”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@sub-record-check:10] NoOp(“SIP/688-000000e4”, “Recordings initialized”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@sub-record-check:11] ExecIf(“SIP/688-000000e4”, “0?Set(ARG3=dontcare)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@sub-record-check:12] Set(“SIP/688-000000e4”, “REC_POLICY_MODE_SAVE=”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@sub-record-check:13] ExecIf(“SIP/688-000000e4”, “0?Set(REC_STATUS=NO)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@sub-record-check:14] GotoIf(“SIP/688-000000e4”, “5?checkaction”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx_builtins.c: Goto (sub-record-check,s,17)
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@sub-record-check:17] GotoIf(“SIP/688-000000e4”, “1?sub-record-check,exten,1”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx_builtins.c: Goto (sub-record-check,exten,1)
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [exten@sub-record-check:1] NoOp(“SIP/688-000000e4”, “Exten Recording Check between 688 and 69”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [exten@sub-record-check:2] Set(“SIP/688-000000e4”, “CALLTYPE=internal”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [exten@sub-record-check:3] ExecIf(“SIP/688-000000e4”, “0?Set(CALLTYPE=)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [exten@sub-record-check:4] Set(“SIP/688-000000e4”, “CALLEE=dontcare”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [exten@sub-record-check:5] ExecIf(“SIP/688-000000e4”, “0?Set(CALLEE=dontcare)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [exten@sub-record-check:6] GotoIf(“SIP/688-000000e4”, “0?callee”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [exten@sub-record-check:7] GotoIf(“SIP/688-000000e4”, “1?caller”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx_builtins.c: Goto (sub-record-check,exten,13)
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [exten@sub-record-check:13] Set(“SIP/688-000000e4”, “RECMODE=dontcare”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [exten@sub-record-check:14] ExecIf(“SIP/688-000000e4”, “0?Set(RECMODE=dontcare)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [exten@sub-record-check:15] ExecIf(“SIP/688-000000e4”, “1?Set(RECMODE=dontcare)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [exten@sub-record-check:16] Gosub(“SIP/688-000000e4”, “recordcheck,1(dontcare,internal,69)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [recordcheck@sub-record-check:1] NoOp(“SIP/688-000000e4”, “Starting recording check against dontcare”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [recordcheck@sub-record-check:2] Goto(“SIP/688-000000e4”, “dontcare”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx_builtins.c: Goto (sub-record-check,recordcheck,3)
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [recordcheck@sub-record-check:3] Return(“SIP/688-000000e4”, “”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [exten@sub-record-check:17] Return(“SIP/688-000000e4”, “”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-exten-vm:13] Macro(“SIP/688-000000e4”, “dial-one,Ttr,69”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:1] Set(“SIP/688-000000e4”, “DEXTEN=69”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:2] Set(“SIP/688-000000e4”, “__CRM_SOURCE=688”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:3] ExecIf(“SIP/688-000000e4”, “0?Set(EXTTOCALL=69)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:4] Set(“SIP/688-000000e4”, “DIALSTATUS_CW=”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:5] GosubIf(“SIP/688-000000e4”, “0?screen,1()”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:6] GosubIf(“SIP/688-000000e4”, “0?cf,1()”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:7] GotoIf(“SIP/688-000000e4”, “1?skip1”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx_builtins.c: Goto (macro-dial-one,s,10)
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:10] GotoIf(“SIP/688-000000e4”, “0?nodial”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:11] GotoIf(“SIP/688-000000e4”, “0?continue”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:12] Set(“SIP/688-000000e4”, “EXTHASCW=ENABLED”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:13] GotoIf(“SIP/688-000000e4”, “0?next1:cwinusebusy”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx_builtins.c: Goto (macro-dial-one,s,25)
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:25] GotoIf(“SIP/688-000000e4”, “0?next3:continue”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx_builtins.c: Goto (macro-dial-one,s,27)
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:27] GotoIf(“SIP/688-000000e4”, “0?nodial”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:28] GosubIf(“SIP/688-000000e4”, “1?dstring,1():dlocal,1()”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [dstring@macro-dial-one:1] Set(“SIP/688-000000e4”, “DSTRING=”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [dstring@macro-dial-one:2] Set(“SIP/688-000000e4”, “DEVICES=69”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [dstring@macro-dial-one:3] ExecIf(“SIP/688-000000e4”, “0?Return()”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [dstring@macro-dial-one:4] ExecIf(“SIP/688-000000e4”, “0?Set(DEVICES=9)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [dstring@macro-dial-one:5] Set(“SIP/688-000000e4”, “LOOPCNT=1”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [dstring@macro-dial-one:6] Set(“SIP/688-000000e4”, “ITER=1”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [dstring@macro-dial-one:7] Set(“SIP/688-000000e4”, “THISDIAL=SIP/69”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [dstring@macro-dial-one:8] GosubIf(“SIP/688-000000e4”, “1?zap2dahdi,1()”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [zap2dahdi@macro-dial-one:1] ExecIf(“SIP/688-000000e4”, “0?Return()”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [zap2dahdi@macro-dial-one:2] Set(“SIP/688-000000e4”, “NEWDIAL=”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [zap2dahdi@macro-dial-one:3] Set(“SIP/688-000000e4”, “LOOPCNT2=1”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [zap2dahdi@macro-dial-one:4] Set(“SIP/688-000000e4”, “ITER2=1”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [zap2dahdi@macro-dial-one:5] Set(“SIP/688-000000e4”, “THISPART2=SIP/69”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [zap2dahdi@macro-dial-one:6] ExecIf(“SIP/688-000000e4”, “0?Set(THISPART2=DAHDI/69)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [zap2dahdi@macro-dial-one:7] Set(“SIP/688-000000e4”, “NEWDIAL=SIP/69&”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [zap2dahdi@macro-dial-one:8] Set(“SIP/688-000000e4”, “ITER2=2”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [zap2dahdi@macro-dial-one:9] GotoIf(“SIP/688-000000e4”, “0?begin2”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [zap2dahdi@macro-dial-one:10] Set(“SIP/688-000000e4”, “THISDIAL=SIP/69”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [zap2dahdi@macro-dial-one:11] Return(“SIP/688-000000e4”, “”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [dstring@macro-dial-one:9] GotoIf(“SIP/688-000000e4”, “1?docheck”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx_builtins.c: Goto (macro-dial-one,dstring,14)
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [dstring@macro-dial-one:14] GotoIf(“SIP/688-000000e4”, “0?skipset”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [dstring@macro-dial-one:15] Set(“SIP/688-000000e4”, “DSTRING=SIP/69&”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [dstring@macro-dial-one:16] Set(“SIP/688-000000e4”, “ITER=2”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [dstring@macro-dial-one:17] GotoIf(“SIP/688-000000e4”, “0?begin”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [dstring@macro-dial-one:18] ExecIf(“SIP/688-000000e4”, “0?Return()”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [dstring@macro-dial-one:19] Set(“SIP/688-000000e4”, “DSTRING=SIP/69”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [dstring@macro-dial-one:20] Return(“SIP/688-000000e4”, “”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:29] GotoIf(“SIP/688-000000e4”, “0?nodial”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:30] GotoIf(“SIP/688-000000e4”, “0?skiptrace”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:31] GosubIf(“SIP/688-000000e4”, “1?ctset,1():ctclear,1()”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [ctset@macro-dial-one:1] Set(“SIP/688-000000e4”, “DB(CALLTRACE/69)=688”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [ctset@macro-dial-one:2] Return(“SIP/688-000000e4”, “”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:32] Set(“SIP/688-000000e4”, “D_OPTIONS=Ttr”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:33] NoOp(“SIP/688-000000e4”, "Blind Transfer: , Attended Transfer: , User: 688, Alert Info: ") in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:34] ExecIf(“SIP/688-000000e4”, “1?Set(ALERT_INFO=)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:35] ExecIf(“SIP/688-000000e4”, “0?Set(ALERT_INFO=)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:36] ExecIf(“SIP/688-000000e4”, “0?Set(ALERT_INFO=)”) in new stack
[2018-04-03 09:21:49] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:37] ExecIf(“SIP/688-000000e4”, “0?Set(ALERT_INFO=Normal;volume=)”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:38] ExecIf(“SIP/688-000000e4”, “0?Set(ALERT_INFO=Normal;volume=)”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:39] GosubIf(“SIP/688-000000e4”, “0?func-set-sipheader,s,1(Alert-Info,)”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:40] ExecIf(“SIP/688-000000e4”, “0?Set(CHANNEL(musicclass)=)”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:41] GosubIf(“SIP/688-000000e4”, “0?qwait,1()”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:42] Set(“SIP/688-000000e4”, “__CWIGNORE=”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:43] Set(“SIP/688-000000e4”, “__KEEPCID=TRUE”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:44] GotoIf(“SIP/688-000000e4”, “0?usegoto,1”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:45] GotoIf(“SIP/688-000000e4”, “0?godial”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:46] Gosub(“SIP/688-000000e4”, “sub-presencestate-display,s,1(69)”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@sub-presencestate-display:1] Goto(“SIP/688-000000e4”, “state-not_set,1”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx_builtins.c: Goto (sub-presencestate-display,state-not_set,1)
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [state-not_set@sub-presencestate-display:1] Set(“SIP/688-000000e4”, “PRESENCESTATE_DISPLAY=”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [state-not_set@sub-presencestate-display:2] Return(“SIP/688-000000e4”, “”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:47] Set(“SIP/688-000000e4”, “CONNECTEDLINE(name,i)=ucuptes”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:48] Set(“SIP/688-000000e4”, “CONNECTEDLINE(num)=69”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:49] Set(“SIP/688-000000e4”, “D_OPTIONS=TtrI”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:50] Macro(“SIP/688-000000e4”, “dialout-one-predial-hook,”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dialout-one-predial-hook:1] MacroExit(“SIP/688-000000e4”, “”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:51] ExecIf(“SIP/688-000000e4”, “0?Set(D_OPTIONS=trII)”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:52] NoOp(“SIP/688-000000e4”, “”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-dial-one:53] Dial(“SIP/688-000000e4”, “SIP/69,TtrIb(func-apply-sipheaders^s^1)”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] netsock2.c: Using SIP RTP TOS bits 184
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] netsock2.c: Using SIP RTP CoS mark 5
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] app_stack.c: SIP/69-000000e5 Internal Gosub(func-apply-sipheaders,s,1) start
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf(“SIP/69-000000e5”, “0?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp(“SIP/69-000000e5”, “Applying SIP Headers to channel”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@func-apply-sipheaders:3] Set(“SIP/69-000000e5”, “SIPHEADERKEYS=”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@func-apply-sipheaders:4] While(“SIP/69-000000e5”, “0”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] app_while.c: Jumping to priority 8
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] pbx.c: Executing [s@func-apply-sipheaders:9] Return(“SIP/69-000000e5”, “”) in new stack
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] app_stack.c: Spawn extension (from-internal, 69, 1) exited non-zero on ‘SIP/69-000000e5’
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] app_stack.c: SIP/69-000000e5 Internal Gosub(func-apply-sipheaders,s,1) complete GOSUB_RETVAL=
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] app_dial.c: Called SIP/69
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] app_dial.c: Connected line update to SIP/688-000000e4 prevented.
[2018-04-03 09:21:50] VERBOSE[15945][C-00000078] app_dial.c: SIP/69-000000e5 is ringing
[2018-04-03 09:21:54] VERBOSE[15945][C-00000078] app_dial.c: Connected line update to SIP/688-000000e4 prevented.
[2018-04-03 09:21:54] VERBOSE[15945][C-00000078] app_dial.c: SIP/69-000000e5 answered SIP/688-000000e4
[2018-04-03 09:21:54] VERBOSE[15982][C-00000078] bridge_channel.c: Channel SIP/69-000000e5 joined ‘simple_bridge’ basic-bridge
[2018-04-03 09:21:54] VERBOSE[15945][C-00000078] bridge_channel.c: Channel SIP/688-000000e4 joined ‘simple_bridge’ basic-bridge
[2018-04-03 09:22:05] WARNING[1994] chan_sip.c: Retransmission timeout reached on transmission 48211559-22933-9@BA.BH.CH.CAJ for seqno 81 (Critical Response) – See https://wiki.asterisk.org/wiki/display/AST/SIP+Retransmissions
Packet timed out after 10496ms with no response
[2018-04-03 09:22:05] WARNING[1994] chan_sip.c: Hanging up call 48211559-22933-9@BA.BH.CH.CAJ - no reply to our critical packet (see https://wiki.asterisk.org/wiki/display/AST/SIP+Retransmissions).
[2018-04-03 09:22:05] VERBOSE[15945][C-00000078] bridge_channel.c: Channel SIP/688-000000e4 left ‘native_rtp’ basic-bridge
[2018-04-03 09:22:05] VERBOSE[15982][C-00000078] bridge_channel.c: Channel SIP/69-000000e5 left ‘native_rtp’ basic-bridge
[2018-04-03 09:22:05] VERBOSE[15945][C-00000078] app_macro.c: Spawn extension (macro-dial-one, s, 53) exited non-zero on ‘SIP/688-000000e4’ in macro ‘dial-one’
[2018-04-03 09:22:05] VERBOSE[15945][C-00000078] app_macro.c: Spawn extension (macro-exten-vm, s, 13) exited non-zero on ‘SIP/688-000000e4’ in macro ‘exten-vm’
[2018-04-03 09:22:05] VERBOSE[15945][C-00000078] pbx.c: Spawn extension (ext-local, 69, 2) exited non-zero on ‘SIP/688-000000e4’
[2018-04-03 09:22:05] VERBOSE[15945][C-00000078] pbx.c: Executing [h@ext-local:1] Macro(“SIP/688-000000e4”, “hangupcall,”) in new stack
[2018-04-03 09:22:05] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-hangupcall:1] GotoIf(“SIP/688-000000e4”, “1?theend”) in new stack
[2018-04-03 09:22:05] VERBOSE[15945][C-00000078] pbx_builtins.c: Goto (macro-hangupcall,s,3)
[2018-04-03 09:22:05] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-hangupcall:3] ExecIf(“SIP/688-000000e4”, “0?Set(CDR(recordingfile)=)”) in new stack
[2018-04-03 09:22:05] VERBOSE[15945][C-00000078] pbx.c: Executing [s@macro-hangupcall:4] Hangup(“SIP/688-000000e4”, “”) in new stack
[2018-04-03 09:22:05] VERBOSE[15945][C-00000078] app_macro.c: Spawn extension (macro-hangupcall, s, 4) exited non-zero on ‘SIP/688-000000e4’ in macro ‘hangupcall’
[2018-04-03 09:22:05] VERBOSE[15945][C-00000078] pbx.c: Spawn extension (ext-local, h, 1) exited non-zero on ‘SIP/688-000000e4’
