sepertinya saya melakukan beberapa percobaan yang mengakibatkan tidak tampilnya operator panel, dan ditambah saya lupa backup sebelum di rubah-rubah. menu operator saya seperti ini
dan di elastisk full log n ya
[2016-10-24 11:54:37] NOTICE[7225] manager.c: 127.0.0.1 failed to authenticate as ‘admin’
[2016-10-24 11:54:38] NOTICE[7227] manager.c: 127.0.0.1 failed to authenticate as ‘admin’
saya coba restart amporttal hasilnya sbb, apakah pesan dibawah ini berhubungan dengan masalah yang saya alami,
mohon bantuannya
thx
Please wait…
STOPPING ASTERISK
Waiting for Asterisk to Stop Gracefully…
Asterisk Stopped
STOPPING FOP SERVER
FOP Server Stopped
SETTING FILE PERMISSIONS
chattr: Operation not supported while reading flags on /var/www/html/assets
Permissions OK
Removing any dangling symlinks
Dangling symlinks removed
STARTING ASTERISK
Asterisk Started
STARTING FOP SERVER
defined(@array) is deprecated at /var/www/html/admin/modules/fw_fop/op_server.pl line 2071.
(Maybe you should just omit the defined()?)
defined(@array) is deprecated at /var/www/html/admin/modules/fw_fop/op_server.pl line 2155.
defined(@array) is deprecated at /var/www/html/admin/modules/fw_fop/op_server.pl line 2198.
defined(%hash) is deprecated at /var/www/html/admin/modules/fw_fop/op_server.pl line 2723.
defined(@array) is deprecated at /var/www/html/admin/modules/fw_fop/op_server.pl line 5814.
defined(@array) is deprecated at /var/www/html/admin/modules/fw_fop/op_server.pl line 5996.
defined(@array) is deprecated at /var/www/html/admin/modules/fw_fop/op_server.pl line 8488.
defined(@array) is deprecated at /var/www/html/admin/modules/fw_fop/op_server.pl line 10458.
defined(@array) is deprecated at /var/www/html/admin/modules/fw_fop/op_server.pl line 10480.
defined(@array) is deprecated at /var/www/html/admin/modules/fw_fop/op_server.pl line 10504.
FOP Server Started
