Asterisk tidak berjalan di elastix
Saya menggunakan Elastix 2.5. saya kurang paham soal scrpit, berikut hasil lognya
[root@primary ~]# asterisk -r
Unable to connect to remote asterisk (does /var/run/asterisk/asterisk.ctl exist? )
[root@primary ~]# amportal start
Please wait…
SETTING FILE PERMISSIONS
chattr: Operation not supported while reading flags on /var/www/html/assets
Permissions OK
Removing any dangling symlinks
Dangling symlinks removed
STARTING ASTERISK
mpg123: no process killed
Asterisk could not start!
Use ‘tail /var/log/asterisk/full’ to find out why.
[root@primary ~]# tail /var/log/asterisk/full
[2016-10-06 22:12:45] WARNING[20624] pbx_config.c: Unable to register extension at line 2385 of /etc/asterisk/extensions_additional.conf
[2016-10-06 22:12:45] ERROR[20624] pbx.c: You have to be kidding-- add exten ‘’ to context park-return-routing? Figure out a name and call me back. Action ignor ed.
[2016-10-06 22:12:45] WARNING[20624] pbx_config.c: Unable to register extension at line 2386 of /etc/asterisk/extensions_additional.conf
[2016-10-06 22:12:45] ERROR[20624] pbx.c: You have to be kidding-- add exten ‘’ to context park-hints? Figure out a name and call me back. Action ignored.
[2016-10-06 22:12:45] WARNING[20624] pbx_config.c: Unable to register extension at line 2400 of /etc/asterisk/extensions_additional.conf
[2016-10-06 22:12:45] WARNING[20624] pbx_config.c: Unable to register extension at line 2401 of /etc/asterisk/extensions_additional.conf
[2016-10-06 22:12:45] WARNING[20624] pbx.c: Unable to register extension ‘*85’ p riority -1 in ‘park-hints’, already in use
[2016-10-06 22:12:45] WARNING[20624] pbx_config.c: The use of ‘_.’ for an extens ion is strongly discouraged and can have unexpected behavior. Please use ‘_X.’ instead at line 3817 of /etc/asterisk/extensions_additional.conf
[2016-10-06 22:12:45] WARNING[20624] pbx_conYou have new mail in /var/spool/mail /root
[root@primary ~]#
[root@primary ~]#
itu harus saya apakan? please tolong bantu
